hello,
I wanna remove a NAT with specific SRC-Address (with specific IP address) , using php api.
any help is appreciated.
hello,
This is easy enough to do.
Is the src-address unique to a single nat or multiple entries?
if possible, post the output of:
/ip firewall nat print
Thanks for the reply,
I need something like this :
$API->write('/ip/firewall/nat', false);
$API->write('=remove=where', false);
$API->write('=src-address=222.222.222.222');
But I have no idea if its correct, would you please help me ?
Regards.
In order to remove an item, you have to retrieve it’s .id using a query first and then issue a remove command.
// ....connect api, etc, etc
// query api for all matching entries
$API->write('/ip/firewall/nat/getall',false); // getall ip firewall nat entries
$API->write('?src-address=222.222.222.222',false); // where src-address=222.222.222.222
$API->write('=.proplist=.id'); // only return the .id (optional)
$READ = $API-read(true); //read the response and parse it. $READ is now an array of all the matches
// if there are more than 1 matches, the array $READ will have more than one element
// if there are no matches, $READ will be empty
foreach($READ as $item){ // loop through all the matches
$API->write('/ip/firewall/nat/remove',false); // remove an /ip firewall nat entry
$API->write('=.id=' . $item['.id']); // where .id = the retrieved value.
$READ = $API->read(true); // read the response
// to be done: do something with the response
(I couldn’t get the forum to nicely space the comments)
I would test this on a non-production device first.
Thank you very much for the great reply,
It worked like a charm!
and one more question please :
Can I use from this code to remove connections (ip firewall connection) ?
Thanks again ![]()
