How to remove/unmount cAP XL ac?
Hello everyone,
Does anyone have manual or experience how to physically unmount cAP XL ac from celling/wall holder?
Old models can be removed by turning the cAP device, what about cAP XL ac?
I saw there is a latch on holder. Do i need to press it somehow? As it seems it is hard to reach when mounted.
there’s just a strong latch, slide the device to the side opposite the cables
The other way around from mounting it.
Slide it off the bracket.
You did not mount the device, i suppose ?
