how to remove user after 30 days automaticlly?
pleas helpe me how to remove user’s from the users list after 30 days automaticly after first use (firs time online ) >>
can do that or not ??
am use hotspot , mikrotik v.2.9.27
pleas helpe me ?
you are using an illegal version. buy a RouterOS license and we will help
i have a licence version . !!!
what do you say !!
Hi community,
I´m from Brazil and i want to know limit password by time when i created user. (command set in terminal)
For example: password have two hours validity. After this the user lasted the access.
It’s possible?
What is the cli command?
Anybody help?
Update to the latest version.
Install RouterOS v4.11
i can’t >> 2,9,27 is level 6
why not this version !!
The license level has nothing to do with being able to upgrade versions. Version != license level.
2.9 is out of support. Upgrade.
Look:
http://forum.mikrotik.com/t/how-to-add-limit-time-in-cli-command-user-add/40187/1
Hi Mecano..
for sure this is illegal version as knew well by all the mikrotik supporter.
to purchase the original, it’s just cost you USD45++ only…
