how to remove web-proxy1 from store
Hi dears,
i enabled web proxy and uply filter and nat rules in mikrotik routeros pc,
suddenly i lost internet access and browser saying unable to connect to internet,
so now i disable web proxy and also reinstall new mikrotik but
1- i am not able to remove web-proxy1 from stores
and
2- in web-proxy setting status still uptime start running when i configure new hotspot mikrotik.
These are the errors when i install new mikrotik hotspot
in ip firewall filter and nat rules saying
;;;place hotspot rules here
plz help
i have these rules
Code:
[admin@AP_HQ] /ip firewall filter> print all detail
0 D chain=forward action=jump jump-target=hs-unauth hotspot=from-client,!auth
1 D chain=forward action=jump jump-target=hs-unauth-to hotspot=to-client,!auth
2 D chain=input action=jump jump-target=hs-input hotspot=from-client
3 I chain=hs-input action=jump jump-target=pre-hs-input
4 D chain=hs-input action=accept protocol=udp dst-port=64872
5 D chain=hs-input action=accept protocol=tcp dst-port=64872-64875
6 D chain=hs-input action=jump jump-target=hs-unauth hotspot=!auth
7 D chain=hs-unauth action=reject reject-with=tcp-reset protocol=tcp
8 D chain=hs-unauth action=reject reject-with=icmp-net-prohibited
9 D chain=hs-unauth-to action=reject reject-with=icmp-host-prohibited
10 X ;;; place hotspot rules here
chain=unused-hs-chain action=passthrough
Code:
[admin@AP_HQ] /ip firewall nat> print all detail
0 D chain=dstnat action=jump jump-target=hotspot hotspot=from-client
1 I chain=hotspot action=jump jump-target=pre-hotspot
2 D chain=hotspot action=redirect to-ports=64872 protocol=udp dst-port=53
3 D chain=hotspot action=redirect to-ports=64872 protocol=tcp dst-port=53
4 D chain=hotspot action=redirect to-ports=64873 protocol=tcp hotspot=local-dst dst-port=80
5 D chain=hotspot action=redirect to-ports=64875 protocol=tcp hotspot=local-dst dst-port=443
6 D chain=hotspot action=jump jump-target=hs-unauth protocol=tcp hotspot=!auth
7 D chain=hotspot action=jump jump-target=hs-auth protocol=tcp hotspot=auth
8 D chain=hs-unauth action=redirect to-ports=64874 protocol=tcp dst-port=80
9 D chain=hs-unauth action=redirect to-ports=64874 protocol=tcp dst-port=3128
10 D chain=hs-unauth action=redirect to-ports=64874 protocol=tcp dst-port=8080
11 D chain=hs-unauth action=redirect to-ports=64875 protocol=tcp dst-port=443
12 I chain=hs-unauth action=jump jump-target=hs-smtp protocol=tcp dst-port=25
13 D chain=hs-auth action=redirect to-ports=64874 protocol=tcp hotspot=http
14 I chain=hs-auth action=jump jump-target=hs-smtp protocol=tcp dst-port=25
15 X ;;; place hotspot rules here
16 ;;; masquerade hotspot network
chain=srcnat action=masquerade src-address=10.5.50.0/24
plz help me that how i will resolve this issue,
