How to replace firewall with MK
Hi, everyone i’m new in mikrotik and i want to change my firewall.
why i want to change ? ans is: because its utm is expire i don’t want to buy i’m facing issue is web filtering
in my scenario i have firewall with multiple ISP’s
and i have LAN+WIFI user with active 300+ user
can i install MK?
Please suggest any idea or i share my configuration
sure, it can be done. You would probably need a good dedicated router and maybe a separate switch depending on how the infrastructure network would look like.
BUT
you would need to get your “hands dirty” to fine tune the config, as it won’t be out of the box.
Are you up to it?
