how to replace or not to show "Mikrotik" screen text...
As subject..
Due to some certain reason, we would like to know..
How we going to replace or not to show the “Mikrotik” screen text after telnet into the RB.
I have saw somebody do that, and this can help us to avoid some unnecessary issue.
if you are a distributor, you have this ability in your mikrotik.com account in “branding package maker” section
oh..
But we are the WISP over here..
Sometime when we show to the customer via telnet, they will ask a lot of about it and that’s hard to skip that and this become some concern to us.
Beside this, can we also remove the help option when telnet into the mikrotik via winbox?
Thanks for you sharing.
you can also change the help link, if you make the branding. contact mikrotik support and we will see what we can do
Noted.
sending the email.
Appreciated for your advice.
