Would it be possible to reset the counters in the Interfaces LTE or PPP-Client?
I has find for interfaces ethernet, but not for the LTE nor PPP…
The only way i can do this at the moment is to reboot the mikrotik device…
Thanks.
Thanks.
This issue has no solution?
What’s new in 6.41rc21 (2017-Sep-01 08:56):
*) interface - added “/interface reset-counters” command (CLI only);
Awesome. That did reset the counters. A lot of hidden gems to learn.
