How to reset Hap Ax Lite LTE6, doesn't work with pressing reset
following the reset sequence (plug power while reset button is pressed, and wait until green light blinks) don’t work for me. I’ve tried to wait for the green light to go blinking 1x to maybe 8x, then release the reset button, but still, the router won’t reset.
I’ve watched youtube videos of reseting hap ax lite, but that didn’t work here. Any tips?
And still that's how it has to be done.
Worked for me on AX Lite and AX Lite LTE.
Hold reset, power on device, when green light comes on, release reset.
But be careful you are sure that reset button is kept pressed when applying power !
Indeed - always struggle with this a little bit as you run out of hands!
Try also the other bootloader, see:
Is there any timing to be done? I hold on to reset until the first blink. Also 2nd blink, sometimes up to 5 blink before release, still not working.
But I think i am doing it properly. But I wonder why it won't work.
