How to reset logging to default settings?
While debugging a problem with /tool/fetch I entered the command /system logging add topics=fetch. Now lots of unwanted messages are logged (attached).
How can I reset logging to default settings? I tried:
/system logging disable [find topics=fetch]
/system logging reset 4
/system logging disable [find topics=raw]
/system logging disable [find topics=write]
without success. Here are the current settings:
/system logging print
Flags: * - DEFAULT
Columns: TOPICS, ACTION
#   TOPICS    ACTION
0 * info      memory
1 * error     memory
2 * warning   memory
3 * critical  echo
4   fetch     memory
/system logging action print
Flags: * - default
 0 * name="memory" target=memory memory-lines=1000 memory-stop-on-full=no
 1 * name="disk" target=disk disk-file-name="log" disk-lines-per-file=1000 disk-file-count=2 disk-stop-on-full=no
 2 * name="echo" target=echo remember=yes
 3 * name="remote" target=remote remote=0.0.0.0 remote-port=514 src-address=0.0.0.0 bsd-syslog=no
     syslog-time-format=bsd-syslog syslog-facility=daemon syslog-severity=auto
/system logging remove 4
Worked! Many thanks!
