hi, Just checking – how do I reset this ? Have tried the paperclip to the 2 piece metal coin / circle – without luck.
BTW: I’ve forgotten the password. Thanks
No power.
Push the button and keep it pressed.
Plug in the powercable.
Wait until user led starts blinking.
Release the clip
Hi Dude2048, Thanks for your reply.
I have POE – so no power cable – or would it be the same ?
“Push the button and keep it pressed.” – what button is this? Thanks
A small hole with reset written. Paperclip needed. Poe should work.
Hi Dude2048, Thanks again for your reply.
I have the board only – so there’s no reset button
https://www.gowifi.co.nz/images/stories/virtuemart/product/RB911G-2HPND.jpg
https://m.youtube.com/watch?v=rv3vVamcSbk
I assumed there was a button. There is not. The two half moon is the reset.
OK – guys - got it working – I must have erroneously pressed CAPSLOCK when I put in the password.
Thought about it – and I’m in. Thanks chaps.
