hello masters all… please help me, how to reset users manager?? because I forgot the password to access the user manager.
thanks for the help
thanks for the help
ok no need to reset usermanage. just open your usermanager router in winbox and in terminal just type this command
/tool usermanager customer print
after this you will get the usernam and password of your usermanager.
please give me karma is i solved your problem
ok thanks bhrother…
1 of those useful posts that live on helping.
Update:
Tested on OS 5.14 & 5.19
/tool user-manager customer print
Thanks for original post!
hi,
but you have not given me karama. i am waiting positively
Update:
Newbeinet its good information i hope so its useful for me and others..
Thanks dear.
hi if the information is useful for . please give me karma so that i will also be inspired to do thsese things
Dear All
I cannot log in to userman, it says invalid username and password.
If I follow you by this: /tool user-manager customer print
It says “database is not accessible, yet”.
You know any other ways I can retrieve my password? or how can I reset it?
Thank you.
Check and be sure user manager is installed and correctly configured.
Dear All
It says “database is not accessible, yet”.You know any other ways I can retrieve my password? or how can I reset it?
Thank you.
