How to Reset Without Shorting The Mikrotik Board?
How do i reset my mikrotik board without shorting the mikrotik 500r5 seriese board
can i use the serial console to reset it how does the serial cable look does any1 have a picture of the serial cable?
Use the serial console. You will need a null modem cable (or standard serial cable with a null modem adapter). I use HyperTerminal in Windows. Then:
/system reset
wuld a vga cable do it ? cause i have a serial cable which has the serial port and at the end a rj45 cable where can i get this null modem cable
No, a VGA cable is for monitors.
Just go to your favourite electronics store. They’ll probably carry it. Newegg does, too. It’s a common piece of equipment.
Hello
Its my first post and i hope it might be usefull.
Use that program NeighborViever → mark on needed device → click on MAC Telnet → Log On and wait a while, press Enter and type system reset, apply and DONE. Your mikrotik has default settings and rebooting.
i live in africa lol it very hard to get sstuff here i only have to mikrotik boards if one goes dwn network goes down lol
how do i log on if i don t knw the password lol
If you don’t know the password, the you need a null modem cable and netinstall. I think there may be a way to do it now all over ethernet (for the 750 at least). Search the forum for the how-to.
i don’t understanding you. Why you go that way? if you dont remember your password to mikrotik, the simply way is using hardware reset… To use serial cable you need phisically acces to this mikrotik… Please explain why you dont do this?? Maybe this is not your board?? hmm??
sorry whats netinstall and i did their aint onther way but the null modem cable
http://wiki.mikrotik.com/wiki/Netinstall
i did download netinstall application but it needs the null modem cable well i got hold of a rs232 connector
i inserted it on the mikrotik board and into the back of my desktop computer the console port tried calling it up with hyper terminal it says connected nothing happens why?
its female on both sides
that wont work make a cable in the manual it shows you how to make one gives you all the pin outs
ok guys great news i got one board to reset by shorting it but i have one board that want short even by the touch of a coin well it will go off and back on but it will just end up bringing the old settings.
i got hold of a cable which has female on one end and the other male but i had the female converter so i put one end of the cable in the mikrotik board and chnge the male end with the female converter i put it on my desktop opened up hyperterminal with these settings :=
115200bit/s, 8 data bits, 1 stop bit, no parity, flow control=none by default.
but nothing loaded up ?
pictures of cable and female converter
onther questions is their any other IC or Electronic Chip on the board i could touch with a coin to short it?
It’s probably not a null modem cable but a serial cable. Check the wiring as per the documentation. Rewire if you have to, or obtain a null modem cable.
Even if you manage to reset via the jumper sooner or later you will want a null modem cable if you’re going to be working with RouterBOARDs.
true i will see what i can do with that cable it suppose to have nine cables inside if i am right onther bad news while shorting the board i blow it up it doesnt on anymore i only have one board working at the momment i will get a tech to fix it for me thanks for all the advices and will try making that cable thanks
where could i buy second hand. good working conditions boards from ?
what models are you looking for
you SA you are in sa what part of SA?
am in malawi lilongwe opening a wisp nearly done just these boards messing with my head when ever i go put them up they end up having a blown up adapter then i have to go up and change it also one show’s good singal the other show very bad singal wonder why better of using nanostations they neva go down but i need the 500r5 series anything with two interface and level 4 licence :>
