Got 2 Cube pro's that I attempted to update firmware a while back and set on shelf.
Ethernet LED does not light with cable plugged in, flashes on boot.
Clearing config & restoring config has failed. LED fails to illuminate. Netinstall also fails.
Long out of warranty, any ideas?
Jerry
netinstall fail = (it wasn't done properly) | (the device became a decorative object)
Try to open them and check the capacitors. I have fixed more than a few RB750/G/Gr3 by changing the capacitors. The symptoms were similar: power LED on, but no network commnication.
