How to restore backup in new Dude
how can I restore backup from old Dude 4 version to this new Dude 6 version. I don’t see anywhere import option, and it would be really painfull to create all maps and devices from scratch in new Dude installation.
With regards,
Sasa
Found way in another post
  • removed dude or dude1 store from x86 ROS,
    -copied .tgz backup file
  • logged in Winbox and opened New terminal
  • imported config using:
dude import-db file=backup-2015.12.08.tgz
I have tried that but with .xml file and it doesnt work
same problem any idea ?
xml backup import problems should be fixed in next rc build.
Same problem here,
Same? After 8 years you have a v4.x Dude database to be imported on v6.x?
