I happen to have duplicate MAC addresses in one network I’m troubleshooting right now, and I suspect people just did ‘export’ in one device and pasted that into another one. I don’t want to invent other MAC addresses nor use locally administered addresses, so please tell me the way to restore MAC that’s built into hardware.
Hi guys, I’ve found two RBs with same MAC address on wlan, maybe a wrong cloning operation.
Is there a way to get factory default mac address without reseting wlan configuration?
Thanks.
Another way to restore a wlan (wlan1 or wlan2) mac address is this:
Note - This only works on a Mikrotik if you have access to it when the wireless if disconnected !!!
1st , make a backup
2nd , using Winbox , in wireless click on [ Reset Configuration]
3rd , now go into wireless and copy the wireless mac address
4th , restore the backup
5th , paste in the correct wlan mac address
6th , make a backup (of your correct configuration)
