How to retrieve Password on my Mikrotik box(433)
I forgot admin password to login to my box.How do I retrieve the password
http://wiki.mikrotik.com/wiki/Password_reset
@normis,Thanks for your reply.
Pls,after reset, I think i will need to reconfigure the box from the scratch?.
yes, you will
@normis, Thanks again,one more question: to login into my box I think i will use Username:admin
then Password field:blank
yes, those will be the defaults after the reset
@normis, Thanks.Good to go for now!
