How to route a device via OpenVPN
I (still) have problems to route a PC to my local network via OpenVPN.
The situation:
  • I’ve got RB411U running as OVPN-client connected to my local network.
    (That means i can ping from RB411U to my local network and vice versa)
  • The PC connected to RB411U cannot ping neither my local network nor the firewall itself.
    It seems that the ping package does not leave the RouterBoard, although I have a route for it…
Here is my routing table of RB411U:
 0 ADS  0.0.0.0/0                          10.112.112.118     1
 1 A S  10.10.10.0/24                      ovpn               1
 2 ADC  10.10.10.1/32      10.10.10.10     ovpn               0
 3 ADC  10.112.112.118/32  77.25.194.85    Vodafone           0
 4 ADS  192.168.55.0/24                    10.10.10.1         1
 5 ADC  192.168.88.0/24    192.168.88.1    LAN                0
Please have also a look at the attached picture.
I have no clue, what the problem could be. If you have got any ideas, please don’t hesitate to post it here.
What is the IP and routing table of your PC? What happen when you run traceroute from your PC?
The PC behind the RouterBoard has got the IP: 192.168.88.40
Its routes are:
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
192.168.88.0    0.0.0.0         255.255.255.0   U     0      0        0 eth0
169.254.0.0     0.0.0.0         255.255.0.0     U     0      0        0 eth0
127.0.0.0       0.0.0.0         255.0.0.0       U     0      0        0 lo
0.0.0.0         192.168.88.1    0.0.0.0         UG    0      0        0 eth0
The traceroute from this PC to 192.168.55.x or to 10.10.10.1 (firewall ovpn-ip) has got only one step: to 192.168.88.1 (which is the RB411U).
When I ping to 192.168.55.x I can see in the RouterBoard logs, that the packet takes the right interface (ovpn), but then its lost:
10:06:29 firewall,info ICMP_LAN: in:LAN out:ovpn, src-mac 00:16:36:ab:da:8c, proto ICMP (type 8, code 0), 192.168.88.40->192.168.55.252, len 64
