How to route EOIP Tunnel to specific interface WAN
hi all,
i need your help , i have 2 router in 2 different site, i’m going to create eoip tunnel in both of them , all router using public address, but i have a problem the eoip not working because one of router have 2 interface LAN .
R1 :
Public Address : 111.222.333.444
R2
Private IP Ether 1 : 222.444.333.111 (WAN 1)
Public Address Ether 2 : 111.122.134.24 (WAN 2)
I’m using PCC ,to split user on my LAN . for some specific LAN IP using WAN 2
the others /24 using WAN 1
when i create eoip in both router, is not working , i think the problem in R2 , because the router has 2 interface WAN.
the situation , i have to create eoip tunnel using Ether 2 / WAN 2 ( because it’s a public address )
please advice .
Best regards,
Add local-address=ip.of.wan.2 to the /interface eoip row at the multi-wan router, and add a dedicated route to the IP of the single-WAN router at the multi-WAN one via WAN2’s gateway.
