Hi there,
I have 5 interfaces on my mikrotik:
Eth1: WAN (PPPoE)
Eth2,3 and 4: LAN (Bridged)
Eth5: LAN2 (to be used for another Public subnet IP)
I connect to my ISP through PPPoE. Once connected, my ISP assign a public IP (let’s say 10.10.10.209) to my WAN interface and I can surf without issue
I also have another Public Subnet (let’s say 50.50.50.248/30) and my ISP routed 50.50.50.248/30 block to me.
I configured IP address 50.50.50.249 to Eth5 and 50.50.50.250 on my PC plugged to Eth5
The PC can surf without Issue but when I check whatsmyip address, I always see the PPPoE IP (10.10.10.209) I tried to disable NAT (excluding Subnet 50.50.50.248/30) but once I did it my PC cannot surf
How can I configure the mikrotik to get my PC connected to Eth5 to surf without NAT
Below what I did:
STEP 1: Assigning IP Addresses to Mikrotik Interface Eth5
add address=50.50.50.249/30 interface=Eth5 network=50.50.50.248
STEP 2: Create Firewall Rule to Allow Connections from Subnet
add action=accept chain=forward connection-state=new out-interface=ether1 src-address=50.50.50.248/30
Thank you for your support
Sob
September 26, 2018, 11:48pm
2
You can try to show us what exactly you did with srcnat. Or just whole firewall.
Hi Sob,
Below the export configuration:
[admin@MikroTik] > /export
sep/27/2018 09:55:47 by RouterOS 6.42.7
software id = LM2B-LKTN
model = RouterBOARD 750 r2
serial number = xxxxxxxxxxxx
add admin-mac=54:51:D1:63:30:6C auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] mtu=1598
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 keepalive-timeout=disabled name=pppoe-out1 password=
SuPdrKxn user=Ben_office
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip hotspot profile
add name=dhcp ranges=192.168.88.10-192.168.88.254
add name=dhcp2 ranges=50.50.50.250
add address-pool=dhcp disabled=no interface=bridge name=defconf
add address-pool=dhcp2 disabled=no interface=ether5 name=DHCP2
/interface detect-internet
set detect-interface-list=all internet-interface-list=WAN lan-interface-list=LAN wan-interface-list=WAN
add address=192.168.88.1/24 comment=defconf interface=bridge network=192.168.88.0
add address=50.50.50.249/30 interface=ether5 network=50.50.50.248
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid interface=ether1
add address=50.50.50.248/30 dns-server=8.8.8.8 gateway=50.50.50.249 netmask=30
add address=192.168.88.0/24 comment=defconf dns-server=8.8.8.8 gateway=192.168.88.1
set allow-remote-requests=yes servers=8.8.8.8
/ip dns static
add address=192.168.88.1 name=router.lan
add action=accept chain=input comment="defconf: accept established,related,untracked" connection-state=
add action=accept chain=forward comment="defconf: accept established,related, untracked" connection-state=
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat
add disabled=yes distance=1 gateway=ether1
/system clock
set time-zone-name=Europe/Brussels
/system routerboard settings
set silent-boot=no
/tool mac-server
/tool mac-server mac-winbox
[admin@MikroTik] > ip route print
0 ADS 0.0.0.0/0 pppoe-out1 1
1 X S 0.0.0.0/0 ether1 1
2 DC 50.50.50.248/30 50.50.50.249 ether5 255
3 ADC 192.168.88.0/24 192.168.88.1 bridge 0
4 ADC 20.20.70.42/32 10.10.10.209 pppoe-out1 0
Thanks for your support
Cheers,
Sob
September 27, 2018, 11:08pm
4
I was interested in this part:
Try to add this before current masquerade rule:
add action=accept chain=srcnat src-address=50.50.50.248/30
Your STEP 2 is useless, firewall already allows outgoing connections. But if you want also incoming, add this before the last drop rule:
add chain=forward dst-address=50.50.50.248/30 action=accept
If it still won’t work, check that the subnet is correctly routed to you. Add this:
/ip firewall mangle
add chain=prerouting dst-address=50.50.50.248/30 in-interface-list=WAN action=log
and then try to send something to 50.50.50.250 from outside (e.g. using some online pinger). You should see incoming packets logged.
