How to route some IP address to other internet gateway
I have 2 interface:
  1. Internet Gateway: 192.168.1.1 (ADSL Modem/Router) with MikroTik IP Address: 192.168.1.1
  2. dynamic public IP from Dial-Up 56k external (serial port) and the internet gateway for example: 203.11.12.13
Local Interface with IP Address: 172.16.0.1-172.16.0.20
How to route internet access for 172.16.0.1-172.16.0.10 to 203.11.12.13 ??
while others to 192.168.1.1
please help me,
thank you…
yudi
I think you can make it with mangle.
do you have any example of it mate?
it will help me a lot… thanks!
:slight_smile:
u have to do policy routing,
//mangle,
/chain=pre-routing src-address “ur lan address block” Action=mark routing, New routing mark “test” pass through=yes
//routing,
/ip route rules then add src-address “ur lan address block” routing mark= “test” action=lookup table=“test”
/ip route add dst-address=“ur lan address block” gateway= “ur chosen gateway” mark=“test”
thnxs,
raktim
