Hello!
I created vlans trough my bridge and I can “ping” each other on the same vlan. The problem is that I just have one gateway. (xxx.xxx.xxx.1), and it is assigned to a phisical port on a mikrotik. The question is: How do I route all the vlans with just one ip address for gateway?
The VLANs are usually addressed with different sub-nets. That’s means, you cannot only one IP address on router. Each VLAN needs own address on router, published as a default gateway.
