Just bought new router, but I cannot figure out how to correctly do some things.
I have subnet 8x.xx.xx.xx/29 wich I need to be accessible from WAN.
I`m not quite sure where to start.
There is nothing like DMZ in Mikrotik’s world.
You have full control on every interface, rule etc.
Please describe what do you want to do? Subnet 8x.yy.zz.uu is public subnet so what is the problem?
How does routing work? Is it static from your ISP or are you peering with a routing protocol? You have to know that first. Assuming this network starting with 8 really is a public network, and it should be with that address. If not, use RFC 1918.
Like the post above says, you can do pretty much anything you want. DMZ isn’t a word here because it’s just another network with whatever access you want it to have.
Do you want to get access to router itself or the LAN behind the router?
