how to run mikrotik from proxy server ???
I have mikrotik Ver 4.16 operating on one pc and it works good for 1 year.
It was working from a DSL router.
My router ip for wan card was 172.30.7.208/24
My router ip was 172.30.7.225 reachable external
Now Our new ISP give us internet from cable with proxy server 192.168.11.200
And port is 8080
When I try the cable on a pc with ip 172.30.7.208 and proxy 192.168.11.200:8080
The internet is working
Now I do not know how to enter the new ISP proxy server for mikrotik input wan card ???
Please help !!!
If my mikrotik working settings helps I can send it here !!!
try this
ip firewall nat
add action=dst-nat chain=dstnat comment="proxy access" disabled=no dst-port=80 protocol=tcp to-addresses=172.30.7.200 to-ports=8080
Thanks for your help but I try and it is not working
this is my rules:
add action=masquerade chain=srcnat comment=“” disabled=no out-interface=
!Internal
add action=redirect chain=dstnat comment=“” disabled=no dst-port=80
in-interface=External protocol=tcp to-ports=8080
add action=redirect chain=dstnat comment=“” disabled=no dst-port=80 protocol=
tcp to-ports=8080
add action=dst-nat chain=dstnat comment=“proxy access” disabled=no dst-port=
80 protocol=tcp to-addresses=192.168.100.228 to-ports=8080
add comment=“” disabled=no distance=1 dst-address=0.0.0.0/0 gateway=
172.30.7.254 scope=30 target-scope=10
add address=172.30.7.208/24 broadcast=172.30.7.255 comment=“” disabled=no
interface=External network=172.30.7.0
add address=172.30.5.252/24 broadcast=172.30.5.255 comment=“” disabled=no
interface=Internal network=172.30.5.0
add address=172.30.4.252/24 broadcast=172.30.4.255 comment=“” disabled=no
interface=Mangers network=172.30.4.0
172.30.7.254 is the router which I take internet from it
192.168.100.228 is the isp proxy server
8080 is the proxy server port
So what is wrong ???
try this
/ip fi nat
add action=dst-nat chain=dstnat comment="proxy access" disabled=no dst-port=\
80 protocol=tcp to-addresses=192.168.100.200 to-ports=8080 place-before=0
No way it is not working
Any other idea
