how to save txt config ??
I have a rb450g set up as radius hotspot and load balancing. Rb433g
Can I copy all the settings on a txt ?? I need compare the settings betweeñ 2 devices.
Go to “files” and click on backup, this file can use on the same type rb
thanks.
Config in readable text format can be exported in file using export command. even export only specific menus you need.
