dcavni
October 31, 2022, 2:44pm
1
Is there any way to secure BtestServer running on Mikrotik so it can be acessed without general rules:
add action=accept chain=input comment="BTEST " protocol=tcp
add action=accept chain=input comment="BTEST " protocol=udp
Without those rules firewall on device doesn’t allow connection to device with Btest client from WAN. I know that i can add certain IP in src. adress but then i cannot test from more locations and i have to change this ip for every test from different location.
with this two rule you destroy all firewall security
nichky
October 31, 2022, 11:43pm
3
extremely basic
#===accept===
add action=accept chain=input dst-port=2000-2100 protocol=udp src-address-list=lan
add action=accept chain=input dst-port=2000-2100 protocol=tcp src-address-list=lan
#===drop===
add action=drop chain=input dst-port=2000-2100 protocol=tcp
add action=drop chain=input dst-port=2000-2100 protocol=udp
/ip firewall address-list add list=lan address=192.168.x.0/24
dcavni
November 1, 2022, 6:08am
4
I know that, that is why i'm asking. I will try the rules above.
dcavni
November 1, 2022, 11:36am
5
If i understand correctly, this only allows btest from 192.168.x.0/24 ?
