how to see if mdix-enabled is YES or NO in an interface??
how can I see if mdix-enabled is YES or NO in an interface??
Auto-MDIX is enabled by default in RouterOS and you cannot disable it.
can’t I disable it with
int eth set mdix-enable=no
Enviado desde mi GT-N7000 usando Tapatalk 2
mdix-enable works only for RB500.
