Hi all,
Is there a way to tell which firewall filter rule is allowing certain traffic to pass, other than adding a unique log prefix to every single rule, running a ping, and then checking the logs?
I am currently able to ping VPN clients from my main VLAN, which IS the behavior I want, but the firewall filter rule that I created to allow that behavior has zero hits on its packet counter. One of the rules higher up must be allowing the traffic to pass, and I can’t figure out which one.
Interestingly, if I set up traceroute with the same source and destination IP as the real world ping, traceroute times out with 100% packet loss. But if I run torch on the interface and then perform the actual ping, I can see the traffic.
Any thoughts on how to best see the interaction with the firewall rules?
