How to select where the traffic goes out through. Router with several IP's on the same interface
We have just migrated our GNU/Linux router to a Mikrotik CCR1009-7G-1C-1S+ . We have mainly a bunch of IP address (public and privat) on the combo1 interface and that’s it But now when doing connections from the router to somewhere , they are failing. For example:
DNS client on the router has stopped working, not able to resolve names anymore, it has two static IP address as a DNS servers.
Telnet to a public ip isn’t working
[admin@router1] > /system telnet 185.69.52.** 443
Trying 185.69.52.**…
^C
Welcome back!
VPN client connection to a server outside isn’t working.
It seems to that that the router messes up with all the interfaces and doesn’t know how to go out. Am I right? Is someone else facing this problem?
Please post your config. I am doing the same thing and it is working for me.
Hi sorry, I thought I had set up the mailing reply on every post.
How can I export my config without compromising my network? It is a pretty large file, so it’s not easy to replace every single IP.
load the config in notepad and do a search/replace for your public IP stuff…
e.g. if your public IPs are all 192.0.2.x, then replace 192.0.2. with x.x.x.
If you have multiple routing prefixes, then use a different prefix for each substitution but be consistent with each one.
So if a second block is 198.51.100.x then replace 198.51.100. with y.y.y.
etc.
Don’t worry about obfuscating private IP addresses because those are unreachable anyway.
I think /export compact hide-sensitive file=MyFile.rsc does what you want.
Right, I think everything has been replaced now, thanks:
# oct/04/2017 12:15:37 by RouterOS 6.40.3
# software id = JSNT-DG49
# model = CCR1009-7G-1C-1S+
# serial number = 7AEC073A28C4
/interface l2tp-server
add disabled=yes name=l2tp-in1 user=jmca
set [ find default-name=combo1 ] comment="INTERFICIE INTERNA - B4"
set [ find default-name=ether1 ] comment="INTERFICIE EXTERNA - A1"
set [ find default-name=ether2 ] comment="Connectat a B2"
set [ find default-name=ether3 ] comment="Connectat a B1"
set [ find default-name=ether4 ] disabled=yes
set [ find default-name=ether5 ] disabled=yes
set [ find default-name=ether6 ] disabled=yes
set [ find default-name=ether7 ] disabled=yes
set [ find default-name=sfp-sfpplus1 ] disabled=yes
/interface vlan
add interface=ether1 name=euronet1 vlan-id=297
add interface=ether1 name=euronet2 vlan-id=597
add interface=ether1 name=eurochat-245 vlan-id=245
add interface=ether1 name=eurochat-545 vlan-id=545
add interface=ether1 name=office2_8 vlan-id=8
add interface=ether1 name=office2_9 vlan-id=9
add comment="VLAN Bridge with old router" interface=ether1 name=vlan98 \
    vlan-id=98
add comment="Adreces externes" interface=ether1 name=vlan99 vlan-id=99
add interface=combo1 name=vlan201 vlan-id=201
add comment="VLAN PRBBgrcert" interface=combo1 name=vlan202 vlan-id=202
add interface=combo1 name=vlan205 vlan-id=205
add interface=combo1 name=vlan206 vlan-id=206
add interface=combo1 name=vlan207 vlan-id=207
add interface=combo1 name=vlan210 vlan-id=210
add interface=combo1 name=vlan223 vlan-id=223
add interface=combo1 name=vlan224 vlan-id=224
add comment="VLAN GESTIO" interface=combo1 name=vlan999 vlan-id=999
add interface=combo1 name=vlan2016 vlan-id=2016
add comment="DMZ - Servidors" interface=combo1 name=vlan2017 vlan-id=2017
add comment="VLAN Usuaris interns" interface=ether3 name=vlan2018 vlan-id=\
    2018
add comment="vlan VPN clients" interface=combo1 name=vlan2019 vlan-id=2019
add comment="VLAN labros" interface=ether2 name=vlan2020 vlan-id=2020
add interface=combo1 name=vlan4001 vlan-id=4001
add interface=combo1 name=vlan4005 vlan-id=4005
add comment="eurochat new 245,545" name=eurochat
add add-arp=yes disabled=no interface=vlan999 name=xarxa-mgmt
add name=L2tp-pool ranges=10.10.10.2-10.10.10.254
add name=clientsinternsgrcert ranges=10.18.200.1-10.18.203.254
add name=gestio-ap-wifi ranges=172.20.132.51-172.20.132.253
add name=nuc-sales ranges=172.20.134.10-172.20.134.254
add name=clients-wifi ranges=172.20.136.40-172.20.139.250
add add-arp=yes address-pool=clientsinternsgrcert disabled=no interface=\
    vlan2018 name=DNSVLAN2018
add add-arp=yes address-pool=clients-wifi disabled=no interface=vlan202 \
    lease-time=8m name=clients-wifi
add add-arp=yes address-pool=gestio-ap-wifi disabled=no interface=vlan205 \
    name=gestio-ap-wifi
add add-arp=yes address-pool=nuc-sales disabled=no interface=vlan207 name=\
    nuc-sales
/ppp profile
set *FFFFFFFE local-address=10.10.10.1 remote-address=L2tp-pool
/queue simple
add burst-limit=25M/25M burst-threshold=22M/22M burst-time=1m/1m max-limit=\
    20M/20M name=office2EXTERN target=office2_8,office2_8
/routing bgp instance
set default as=65245 redistribute-connected=yes redistribute-ospf=yes \
    redistribute-other-bgp=yes redistribute-rip=yes redistribute-static=yes \
    routing-table=IN_73.22.18.130
/tool user-manager customer
set admin access=\
    own-routers,own-users,own-profiles,own-limits,config-payment-gw
/dude
set enabled=yes
/interface l2tp-server server
set enabled=yes use-ipsec=yes
add interface=eurochat-245 list=eurochat
add interface=eurochat-545 list=eurochat
add address=192.168.10.230/24 interface=combo1 network=192.168.10.0
add address=148.124.6.12/24 interface=combo1 network=148.124.6.0
add address=192.168.98.254/24 comment="vlan bridge amb oldrouter" interface=\
    vlan98 network=192.168.98.0
add address=148.125.244.253/24 interface=ether1 network=148.125.244.0
add address=10.99.254.254/16 comment="vlan GESTIO" interface=vlan999 network=\
    10.99.0.0
add address=10.19.254.254/16 comment="IP vlan VPN clients" interface=vlan2019 \
    network=10.19.0.0
add address=148.125.6.254/24 comment="Adre\E7a externa" interface=vlan99 \
    network=148.125.6.0
add address=10.17.254.254/16 comment="VLAN DMZ - Servidors" interface=\
    vlan2017 network=10.17.0.0
add address=73.22.20.6/30 comment=euronet2 interface=euronet2 network=73.22.20.4
add address=10.18.254.254/16 comment="VLAN clients grcert" interface=vlan2018 \
    network=10.18.0.0
add address=148.125.6.253/24 comment="Adre\E7a externa 2" interface=vlan99 \
    network=148.125.6.0
add address=148.125.6.252/24 comment="Adre\E7a externa 3" interface=vlan99 \
    network=148.125.6.0
add address=73.22.16.6/30 comment=euronet1 interface=euronet1 network=73.22.16.4
add address=148.126.191.254/29 comment="office2 Externa" interface=office2_8 \
    network=148.126.191.248
add address=192.168.20.1/24 comment="office2 Interna" interface=office2_9 network=\
    192.168.20.0
add address=192.168.10.30/24 interface=combo1 network=192.168.10.0
add address=148.125.244.254/24 interface=combo1 network=148.125.244.0
add address=148.127.240.254/24 interface=combo1 network=148.127.240.0
add address=148.124.6.8/24 interface=combo1 network=148.124.6.0
add address=192.168.0.254/24 interface=combo1 network=192.168.0.0
add address=172.20.4.99/22 interface=ether2 network=172.20.4.0
add address=172.20.150.253/24 interface=combo1 network=172.20.150.0
add address=172.20.152.253/24 interface=combo1 network=172.20.152.0
add address=172.20.153.253/24 interface=combo1 network=172.20.153.0
add address=172.20.154.253/24 interface=combo1 network=172.20.154.0
add address=172.20.16.253/24 interface=combo1 network=172.20.16.0
add address=148.127.240.200/24 interface=combo1 network=148.127.240.0
add address=148.124.6.254/24 interface=combo1 network=148.124.6.0
add address=148.124.6.200/24 interface=combo1 network=148.124.6.0
add address=148.124.6.151/24 interface=combo1 network=148.124.6.0
add address=148.124.6.152/24 interface=combo1 network=148.124.6.0
add address=148.124.6.153/24 interface=combo1 network=148.124.6.0
add address=148.124.6.154/24 interface=combo1 network=148.124.6.0
add address=148.124.6.155/24 interface=combo1 network=148.124.6.0
add address=148.124.6.156/24 interface=combo1 network=148.124.6.0
add address=148.124.6.157/24 interface=combo1 network=148.124.6.0
add address=148.124.6.158/24 interface=combo1 network=148.124.6.0
add address=148.124.6.150/24 interface=combo1 network=148.124.6.0
add address=192.168.10.254/24 interface=combo1 network=192.168.10.0
add address=192.168.10.31/24 interface=combo1 network=192.168.10.0
add address=192.168.10.32/24 interface=combo1 network=192.168.10.0
add address=172.20.6.201/22 interface=ether2 network=172.20.4.0
add address=172.20.150.254/24 interface=combo1 network=172.20.150.0
add address=192.168.16.2/24 interface=vlan4001 network=192.168.16.0
add address=172.20.135.1/24 interface=vlan201 network=172.20.135.0
add address=172.20.136.1/22 interface=vlan202 network=172.20.136.0
add address=172.20.132.50/24 interface=vlan205 network=172.20.132.0
add address=172.20.132.1/24 interface=vlan205 network=172.20.132.0
add address=172.16.0.1/16 interface=vlan2016 network=172.16.0.0
add address=172.18.0.1/16 disabled=yes interface=vlan2018 network=172.18.0.0
add address=148.127.242.254/24 interface=vlan4005 network=148.127.242.0
add address=172.20.133.1/24 interface=vlan206 network=172.20.133.0
add address=172.20.134.1/24 interface=vlan207 network=172.20.134.0
add address=172.20.130.50/24 interface=vlan210 network=172.20.130.0
add address=172.20.128.254/24 interface=vlan223 network=172.20.128.0
add address=172.20.129.254/24 interface=vlan224 network=172.20.129.0
add address=73.22.18.130/30 comment="eurochat Externes 1" interface=eurochat-245 \
    network=73.22.18.128
add address=73.22.22.130/30 comment="eurochat Externes 2" interface=eurochat-545 \
    network=73.22.22.128
add address=73.22.174.254/24 comment="Externa proves" interface=vlan2017 \
    network=73.22.174.0
add address=73.22.174.253/24 interface=vlan2017 network=73.22.174.0
/ip dhcp-client
add disabled=no
add address=10.18.0.0/16 dns-server=172.20.4.10,172.20.4.18 domain=grcert.es \
    gateway=10.18.254.254 netmask=16 ntp-server=172.20.4.10,172.20.4.18 \
    wins-server=172.20.4.10,172.20.4.18
add address=172.20.132.0/24 dns-server=8.8.8.8,8.8.4.4 gateway=172.20.132.1
add address=172.20.134.0/24 dns-server=8.8.8.8,8.8.4.4 gateway=172.20.134.1
add address=172.20.136.0/22 dns-server=8.8.8.8,8.8.4.4 gateway=172.20.136.1
set servers=8.8.8.8,8.8.4.4
/ip firewall address-list
add address=10.18.0.0/16 list=grcertinternesclients
add address=172.20.4.0/22 list=grcertinternservers
add address=172.20.4.10 comment=Aleph1 list=windowsservers
add address=172.20.4.10 comment="DNS intern" list=InternalDNS
add address=172.20.4.18 comment="DNS Intern" list=InternalDNS
add address=8.8.8.8 comment="DNS externs" list=ExternalDNS
add address=172.20.4.18 comment=Aleph0 list=windowsservers
add address=172.20.4.36 comment=Hermes2 list=windowsservers
add address=10.18.254.54 comment="SSH Cloud router" list=SSHservers
add address=192.168.10.0/24 comment="SSH 192.168.10" list=SSHservers
add address=172.20.4.0/24 comment="CloudStation Server" list=CloudStation
add address=172.20.4.30 comment="Offieuronetn server" list=Offieuronetn
add address=172.20.4.30 comment=Offieuronetn list=windowsservers
add address=172.20.4.47 comment=Folder.grcert.es list=SSHservers
add address=10.18.100.0/24 comment=\
    "RDP - IMW01753 - Susanna Tello i resta de clients RDP workstations" \
    list=RDPClients
add address=10.18.200.0/24 comment="RDP - Temporalment per provar" list=\
    RDPClients
add address=10.18.10.1 list=RDPClients
add address=10.18.10.0/24 list=Sysadmins
add address=172.20.4.84 comment=IMAV0002 list=windowsservers
add address=172.20.4.68 comment=Hermes3 list=windowsservers
add address=172.20.4.0/22 comment=172.20.4.0/22 list=INTERNAL
add address=10.99.0.0/16 comment=10.99.0.0/16 list=INTERNAL
add address=10.17.0.0/16 comment=10.17.0.0/16 list=INTERNAL
add address=10.18.0.0/16 comment=10.18.0.0/16 list=INTERNAL
add address=192.168.10.0/24 comment=192.168.10.0/24 list=INTERNAL
add address=172.20.136.0/22 list=INTERNAL
add address=192.168.20.0/24 list=office2INTERN
add address=10.0.0.0/16 list=office2INTERN
add address=10.1.0.0/16 list=office2INTERN
add address=10.2.0.0/16 list=office2INTERN
add address=172.20.150.0/24 list=INTERNAL
add address=148.124.6.157 list=INTERNAL
add address=148.124.6.158 list=INTERNAL
add address=172.20.7.42 list=Desenvolupament
add address=172.20.7.109 list=Desenvolupament
add address=73.22.16.6 list=AdrecesEnllaceuronet
add address=73.22.20.6 list=AdrecesEnllaceuronet
add address=73.22.16.5 list=AdrecesMonitoratgeeuronet
add address=73.22.20.5 list=AdrecesMonitoratgeeuronet
add address=73.22.7.254 list=AdrecesMonitoratgeeuronet
add address=148.124.6.150 list=INTERNAL
add address=192.168.110.0/24 comment="LAb de recerca de Catalunya" list=\
    INTERNAL
add address=19.23.14.111 list=labrosExternalTargets
add address=clients.idtm.se list=labrosExternalTargets
add address=ftp.pwc.de list=labrosExternalTargets
add address=ftp.red.de list=labrosExternalTargets
add address=148.125.223.123 list=AdrecesMonitoratgeeuronet
add address=172.20.4.0/22 list=labrosInternal
add address=10.18.0.0/16 list=labrosInternal
add address=172.20.4.0/22 list=IntranetIPs
add address=172.20.150.0/24 list=IntranetIPs
add address=10.17.0.0/16 list=IntranetIPs
add address=10.18.0.0/16 list=IntranetIPs
add address=10.19.0.0/16 list=IntranetIPs
add address=192.168.10.0/24 list=IntranetIPs
add address=10.99.0.0/16 list=IntranetIPs
add address=192.168.110.0/24 list=IntranetIPs
add address=172.20.136.0/22 list=IntranetIPs
add address=73.22.12.111 list=AdrecesMonitoratgeeuronet
add address=73.22.18.129 list=AdrecesMonitoratgeeuronet
add address=73.22.22.129 list=AdrecesMonitoratgeeuronet
add address=73.22.174.0/24 list=INTERNAL
add address=172.20.4.25 comment=Sirius list=windowsservers
add action=accept chain=forward comment="Accept stablished and related" \
    connection-mark="" connection-state=established,related
add action=accept chain=forward comment="Allow DNAT connections" \
    connection-nat-state=dstnat
add action=accept chain=forward comment="148.125.244.0 out" dst-port=\
    80,443,53 protocol=tcp src-address=148.125.244.0/24
add action=accept chain=forward dst-port=53 protocol=udp src-address=\
    148.125.244.0/24
add action=accept chain=output comment="148.125.244.253 out" src-address=\
    148.125.244.253
add action=accept chain=input comment="148.125.244.253 ping" dst-address=\
    148.125.244.253 protocol=icmp
add action=accept chain=input comment="Prova IP externa nova" dst-address=\
    73.22.174.1 protocol=icmp
add action=accept chain=forward comment="Obrim tot cap a servidors windows" \
    dst-address-list=windowsservers src-address=10.18.0.0/16
add action=accept chain=forward comment="Cluster cont" connection-state=new \
    protocol=tcp src-address=192.168.10.0/24
add action=accept chain=forward comment="Cluster cont" dst-port=\
    53,389,137,138 protocol=udp src-address=192.168.10.0/24
add action=accept chain=forward comment="Servers interns 172.20.150" \
    connection-state=new dst-address=0.0.0.0/0 dst-port=\
    80,443,22,23,53,139,993,995,145,587,465,53 protocol=tcp src-address=\
    172.20.150.0/24
add action=accept chain=forward dst-address=0.0.0.0/0 dst-port=53,137,138 \
    protocol=udp src-address=172.20.150.0/24
add action=accept chain=forward comment="office2 Intern" dst-address-list=\
    office2INTERN src-address-list=INTERNAL
add action=accept chain=forward comment="office2 Intern IN" protocol=tcp \
    src-address-list=office2INTERN src-port=80,443
add action=accept chain=forward comment="Tot el tr\E0fic office2 extern" \
    dst-address=148.126.190.0/23
add action=accept chain=forward comment="Acc\E9s de office2 extern a nosaltres" \
    dst-port=80,443 out-interface=!euronet1 protocol=tcp src-address=\
    148.126.190.0/23
add action=accept chain=forward comment="office2 de dins extern" out-interface=\
    euronet1 src-address=148.126.190.0/23
add action=accept chain=forward comment="ADMINS to servers" dst-address=\
    10.17.0.0/16 protocol=icmp src-address-list=Sysadmins
add action=accept chain=forward comment="office2 telnet extern" \
    connection-state=related,new dst-address=148.126.191.14 dst-port=23 \
    protocol=tcp src-address=148.124.6.0/24
add action=accept chain=forward comment="Web navigation from 148.124.6.0" \
    dst-port=80,443,53 protocol=tcp src-address=148.124.6.0/24
add action=accept chain=forward comment="DNS from 148.124.6.0" dst-port=53 \
    protocol=udp src-address=148.124.6.0/24
    "Allow access to admin VLAN from admin workstations" connection-state=new \
    dst-address=10.99.0.0/16 src-address-list=Sysadmins
add action=accept chain=forward comment="DMZ servers ssh from VPN" \
    connection-state=new dst-address=10.17.0.0/16 dst-port=22 protocol=tcp \
    src-address=10.19.0.0/16 src-port=""
add action=accept chain=forward comment="Sortida servidors 2017" dst-address=\
    0.0.0.0/0 dst-port=22,80,443,53,587 protocol=tcp src-address=10.17.0.0/16
    0.0.0.0/0 dst-port=53 protocol=udp src-address=10.17.0.0/16
add action=accept chain=input comment="VPN access a interfcie router" \
    dst-address=10.18.254.254 dst-port=443 protocol=tcp src-address=\
    10.19.0.29
    dst-address=172.20.4.99 dst-port=443 protocol=tcp
add action=accept chain=input dst-address=10.17.254.254 protocol=icmp
add action=accept chain=forward connection-state=new dst-address=10.17.10.1 \
    dst-port=8088 protocol=tcp
add action=accept chain=input comment="Ping euronet2" dst-address=73.22.20.6 \
    in-interface=euronet2 protocol=icmp
add action=accept chain=input comment=SNMP dst-address=0.0.0.0/0 dst-port=161 \
add action=accept chain=forward comment="Ping Prometheus monitoritzacio" \
    dst-address=172.20.4.0/22 protocol=icmp src-address=192.168.10.0/24
add action=accept chain=forward dst-address=10.17.0.0/16 protocol=icmp \
add action=accept chain=forward dst-address=10.99.10.1 protocol=tcp
add action=accept chain=input comment="ping 172.18.254.254" dst-address=\
    10.18.254.254 protocol=icmp
add action=drop chain=forward comment="DENY access to admin vlan" disabled=\
    yes dst-address=10.99.0.0
add action=accept chain=input comment="ROUTER interf\EDcie web router" \
    connection-state="" dst-address=10.18.254.254 dst-port=443 in-interface=\
    vlan2018 protocol=tcp src-address-list=Sysadmins src-port=""
    "Acc\E9s cl\FAster cont des-de desenvolupament" dst-address=\
    192.168.10.0/24 src-address-list=Desenvolupament
add action=accept chain=input comment="ROUTER ssh server" connection-state="" \
add action=accept chain=forward comment=RDP connection-state=new \
    dst-address-list=windowsservers dst-port=3389 protocol=tcp \
add action=accept chain=forward comment="Acc\E9s Telnet" \
    connection-nat-state="" connection-state=new dst-port=23,22 protocol=tcp \
    "Acc\E9s telnet a office2 des-de clients" connection-state=new \
    dst-address-list=office2INTERN dst-port=23 protocol=tcp src-address=\
    172.20.4.0/22
add action=accept chain=forward comment=SSH connection-state=new dst-address=\
    172.20.4.0/22 dst-port=22 protocol=tcp src-address-list=\
add action=accept chain=forward comment="office2 extern telnet" dst-address=\
    148.126.191.14 dst-port=23 protocol=tcp src-address=10.18.0.0/16
add action=accept chain=forward comment="Acces a pgadmin de produccio" \
    dst-address=192.168.10.69 dst-port=5050 protocol=tcp src-address=\
    10.18.10.0/24 src-address-list="" src-port=""
    192.168.10.0/24 dst-port=22 protocol=tcp src-address=10.18.0.0/16
add action=accept chain=forward comment="Navegaci\F3 web ports standard" \
    connection-state=new dst-address=0.0.0.0/0 dst-port=80,443 protocol=tcp \
add action=accept chain=forward comment="DNS interns" connection-state=new \
    dst-address=172.20.4.0/22 dst-port=53 protocol=udp src-address=\
    10.18.0.0/16
add action=accept chain=forward comment="DNS Google" connection-state=new \
    dst-address=8.8.8.8 dst-port=53 protocol=udp src-address=10.18.0.0/16
add action=accept chain=forward comment="smtp/imap gmail" dst-port=\
    587,993,465 protocol=tcp src-address=10.18.0.0/16
add action=accept chain=forward comment="Connexi\F3 amb MAILDU" dst-address=\
    192.168.10.61 dst-port=2526 protocol=tcp src-address=172.20.4.36
add action=accept chain=forward comment="Proxy gger 172.20.4.0/22" \
    dst-address=84.89.157.0/24 dst-port=9090 protocol=tcp src-address=\
    172.20.4.0/22
add action=accept chain=forward comment="Host desde nova VPN clients" \
    dst-address-list=office2INTERN dst-port=23 log=yes log-prefix=HOST protocol=\
add action=accept chain=forward comment="Proxy gger" connection-state=new \
    10.18.0.0/16
add action=accept chain=forward comment="SMB, CIFS,  WebDAV" \
    connection-state=new dst-address=172.20.4.0/22 dst-port=\
    135,137,138,139,445,389,636,88,53,5006 protocol=tcp src-address=\
    10.18.0.0/16
add action=accept chain=forward comment="Samba udp" connection-state=new \
    connection-type="" dst-address=172.20.4.0/22 dst-port=\
    389,88,445,464,138,137 protocol=udp src-address=10.18.0.0/16
add action=accept chain=forward comment=trendmicro connection-state=new \
    dst-address-list=grcertinternservers dst-port=8080,4343 protocol=tcp \
    src-address-list=grcertinternesclients
add action=accept chain=forward comment="Access outlook" connection-state=new \
    dst-address=172.20.4.36 dst-port=!25 protocol=tcp src-address-list=\
add action=accept chain=input comment="L2TP Entrada externa" \
    connection-state=new dst-address=148.124.6.12 dst-port=500,4500,1701 \
    protocol=udp
add action=accept chain=forward comment=L2TP connection-state=new \
    dst-address=10.19.0.29 dst-port=500,4500,1701 in-interface=ether1 \
    protocol=udp
add action=accept chain=forward comment=CloudStation connection-state=new \
    dst-address-list=CloudStation dst-port=6690 protocol=tcp \
add action=accept chain=forward dst-address-list=CloudStation dst-port=5001 \
    protocol=tcp
add action=accept chain=forward comment="CloudStation extern" dst-address=\
    148.124.6.1 dst-port=6690 protocol=tcp src-address=0.0.0.0/0
    "Connexi\F3 client Offieuronetn 28844 cal revisar-ho" dst-address-list=\
    Offieuronetn protocol=tcp src-address-list=grcertinternesclients
add action=accept chain=input comment="ping gesti\F3" in-interface=vlan999 \
    protocol=icmp
add action=accept chain=input comment="ping 172.19.254.254" dst-address=\
    10.19.254.254 in-interface=vlan2019
add action=accept chain=forward comment="Offieuronetn reverse" dst-address=\
    10.18.0.0/16 protocol=tcp src-address=172.20.4.30
add action=accept chain=forward comment="VPN - DNS intern" connection-state=\
    new dst-address-list=InternalDNS dst-port=53 protocol=udp src-address=\
    10.19.0.29
add action=accept chain=forward comment="VPN - Proxy Pompeu" \
    connection-state=new dst-address=84.89.157.0/24 dst-port=9090 protocol=\
    tcp src-address=10.19.0.29
    "VPN - Navegaci\F3 ports web estandard" dst-address=0.0.0.0/0 dst-port=\
    80,443 protocol=tcp src-address=10.19.0.29
add action=accept chain=forward comment="VPN - Google DNS" connection-state=\
    new dst-address=8.8.8.8 dst-port=53 protocol=udp src-address=10.19.0.29
    "VPN - Remote Desktop - Windows Server" dst-address-list=windowsservers \
    dst-port=3389 in-interface=vlan2019 protocol=tcp
add action=accept chain=forward comment="VPN - RDP clients" connection-state=\
    new dst-address-list=RDPClients in-interface=vlan2019
add action=accept chain=forward comment="VPN CloudStation" connection-state=\
    new dst-address-list=CloudStation dst-port=6690 protocol=tcp src-address=\
    10.19.0.29
add action=accept chain=forward comment="VPN ssh servers" dst-address-list=\
    SSHservers dst-port=22 protocol=tcp src-address=10.19.0.29
add action=accept chain=forward comment="VPN all ssh" dst-port=22 protocol=\
add action=accept chain=input disabled=yes dst-address=192.168.98.254 \
    in-interface=vlan98
add action=accept chain=input disabled=yes dst-address=148.125.6.254 \
    protocol=icmp
    dst-port=80 protocol=tcp
add action=accept chain=forward disabled=yes dst-address=148.125.6.254
    "Servers grcert i clients antics - Servidor Impressores" connection-state=\
    80,443,22,23,53,993,995,145,587,465,139,445,9100 protocol=tcp \
    src-address=172.20.4.0/22
add action=accept chain=forward comment="Sortida habilitada per labros" \
    connection-state=new dst-port=43389 protocol=tcp src-address-list=\
    labrosInternal
add action=accept chain=forward comment="Laboratori labros" dst-address=\
    185.40.184.84 protocol=tcp src-address-list=labrosInternal
add action=accept chain=forward comment="Lab labros" connection-state=\
    new,untracked dst-address=93.104.247.67 protocol=tcp src-address-list=\
    labrosInternal
add action=accept chain=forward comment="Impressio LPR LDP" dst-address=\
    10.18.0.0/16 dst-port=515,8080,80,443 protocol=tcp src-address=\
    172.20.4.0/22
    "Send mail smtp regicor desde leomessi" dst-address=46.16.61.50 dst-port=\
    578 protocol=tcp src-address=172.20.4.74
add action=accept chain=forward comment="Printer server" dst-address=\
    10.18.0.0/16 dst-port=161,162 protocol=udp src-address=172.20.4.84
add action=accept chain=forward comment="IMAV0002 Printer Server" \
    dst-address=10.18.0.0/16 log=yes log-prefix=PRINTER src-address=\
    172.20.4.84
add action=accept chain=forward comment="Consulta DNS externs" dst-address=\
    0.0.0.0/0 dst-port=53 protocol=udp src-address=172.20.4.0/22
add action=accept chain=forward dst-port=25 protocol=tcp src-address=\
    172.20.4.36
add action=accept chain=forward comment="WIFI clients" connection-state=new \
    dst-address-list=!IntranetIPs dst-port=\
    80,443,22,23,53,993,995,145,587,465,1022 protocol=tcp src-address=\
    172.20.136.0/22
add action=accept chain=forward dst-address-list=!IntranetIPs dst-port=53 \
    protocol=udp src-address=172.20.136.0/22
add action=accept chain=forward comment="VLAN 2016 4. planta" \
    connection-state=new dst-port=80,443,22,23,53,993,995,145,587,465 \
    protocol=tcp src-address=172.16.0.0/16
add action=accept chain=forward comment="SNMP Netdisco cap a Tot" \
    dst-address=0.0.0.0/0 dst-port=137,138,161,219 log=yes log-prefix=\
    NETDISCO protocol=udp src-address=192.168.10.0/24
add action=accept chain=forward comment="VLAN 2016 4. planta" dst-port=53 \
    protocol=udp src-address=172.16.0.0/16
add action=accept chain=forward dst-address=0.0.0.0/0 dst-port=138,139,219 \
add action=accept chain=input comment="Monitoratge euronet" dst-address-list=\
    AdrecesEnllaceuronet protocol=icmp src-address-list=AdrecesMonitoratgeeuronet
add action=accept chain=forward comment="A esborrar JMCA" connection-state=\
    new dst-address=0.0.0.0/0 dst-port=5002 protocol=tcp src-address=\
    10.18.0.0/16
add action=accept chain=forward comment=Unifi dst-port=\
    8080,8081,8443,8880,8843,53 protocol=tcp src-address=172.20.132.0/24
add action=accept chain=forward dst-port=10001,3478,53,123 protocol=udp \
add action=accept chain=forward comment="VPN client gwersb" dst-address=\
    83.55.159.246
add action=accept chain=input comment="Adre\E7a externa eurochat\
    \n" dst-address=73.22.174.0/24 protocol=icmp src-address=0.0.0.0/0
add action=accept chain=forward disabled=yes dst-address=73.22.174.0/24 \
    in-interface=eurochat-245 log-prefix=BLABLA out-interface=vlan2017 protocol=\
    in-interface=eurochat-545 out-interface=vlan2017 protocol=icmp src-address=\
    0.0.0.0/0
add action=accept chain=input in-interface=eurochat-245 protocol=icmp \
add action=accept chain=input in-interface=eurochat-545 protocol=icmp \
    "Traffic entre QUALSEVOL i VLAN Maquinari Xarxa" dst-address=10.99.0.0/16 \
    protocol=tcp src-address=10.18.10.0/24
add action=accept chain=input comment="eurochat BGP" connection-state=new \
    dst-address=73.22.18.130 dst-port=179 protocol=tcp
    dst-address=73.22.22.130 dst-port=179 protocol=tcp
add action=accept chain=input comment="eurochat BGP" dst-address=73.22.18.130 \
    protocol=tcp src-port=179
add action=accept chain=input comment="eurochat BGP" dst-address=73.22.22.130 \
add action=accept chain=forward comment="NETDISCO nou rang xarxa" \
    dst-address=10.99.0.0/16 src-address=0.0.0.0
add action=accept chain=forward comment="WIFI rails" connection-state=\
    related,new dst-address-list=IntranetIPs dst-port=3000 protocol=tcp \
add action=accept chain=forward comment="LDAP TLS" connection-state=new \
    dst-address=172.20.4.10 dst-port=636 protocol=tcp src-address=\
    10.17.0.0/16
add action=accept chain=forward comment="LDAP from SERVERS" dst-address=\
    172.20.4.0/22 dst-port=389 protocol=tcp src-address=10.17.0.0/16
add action=accept chain=forward connection-state=related,new dst-address=\
    10.17.0.0/16 dst-port=3000 protocol=tcp src-address=10.18.0.0/16
    "Obrim conexions sortints cap a FTP i SSH extern" dst-address=0.0.0.0/0 \
    dst-port=22,21 log=yes log-prefix=SFTP-gger protocol=tcp src-address=\
    10.18.0.0/16
add action=accept chain=forward dst-address=10.17.0.0/16 dst-port=3000 \
    protocol=tcp src-address=172.20.4.0/22
add action=accept chain=forward comment="store Silvius" dst-address=\
    10.17.1.1 dst-port=5001 protocol=tcp src-address=10.18.0.0/16
    "Sophie VLAN 2018 cap a casper2.grcert.es" dst-address=172.20.4.20 log=yes \
    log-prefix=PATXI src-address=10.18.100.4
add action=accept chain=forward comment="SSH sortida sysadmins" dst-port=22 \
add action=drop chain=input
/ip firewall mangle
add action=mark-connection chain=prerouting connection-mark=no-mark \
    connection-state=new dst-address=73.22.174.0/24 new-connection-mark=TTT \
    passthrough=yes
add action=mark-routing chain=prerouting connection-mark=TTT \
    connection-nat-state=dstnat new-routing-mark=IN_73.22.18.130 passthrough=\
    no src-address=192.168.10.0/24
add action=mark-connection chain=prerouting dst-address=73.22.174.253 \
    dst-port=22,3000 new-connection-mark=TTT passthrough=yes protocol=tcp
add action=mark-packet chain=prerouting dst-address=73.22.174.253 dst-port=\
    500,4500,1701 new-packet-mark=TTT passthrough=yes protocol=udp
    new-routing-mark=IN_73.22.18.130 passthrough=no
add action=mark-routing chain=prerouting new-routing-mark=IN_73.22.18.130 \
    packet-mark=TTT passthrough=no
add action=mark-packet chain=prerouting dst-address=148.125.244.0/24 \
    new-packet-mark=IN193_145_244 passthrough=yes
add action=mark-packet chain=prerouting comment="eurochat 245" in-interface=\
    eurochat-245 new-packet-mark=IN_73.22.18.130 passthrough=yes
add action=mark-packet chain=prerouting comment="eurochat 545" in-interface=\
    eurochat-545 new-packet-mark=IN_73.22.18.130 passthrough=yes
add action=mark-routing chain=prerouting new-routing-mark=NET193_145_244 \
add action=mark-routing chain=prerouting comment="eurochat 245" new-routing-mark=\
    IN_73.22.18.130 packet-mark=IN_73.22.18.130 passthrough=yes
add action=mark-routing chain=prerouting comment="eurochat 545" new-routing-mark=\
add action=accept chain=prerouting
add action=passthrough chain=unused-hs-chain comment=\
    "place hotspot rules here" disabled=yes
add action=src-nat chain=srcnat disabled=yes dst-address=172.20.4.1 dst-port=\
    22 protocol=tcp src-address-list=!INTERNAL to-addresses=148.125.6.253
add action=src-nat chain=srcnat disabled=yes dst-address=192.168.10.68 \
    dst-port=80 protocol=tcp src-address=0.0.0.0/0 src-address-list=!INTERNAL \
    to-addresses=148.124.6.12
add action=src-nat chain=srcnat dst-address=0.0.0.0/0 out-interface-list=eurochat \
    src-address=192.168.10.69 to-addresses=73.22.174.254
add action=masquerade chain=srcnat comment="Ahir PIN NAT cont cluster" \
    dst-address=192.168.10.61 dst-port=80,443,10443,10080 protocol=tcp \
    src-address=192.168.10.0/24 to-addresses=192.168.10.30
add action=masquerade chain=srcnat comment="Hair pin nat cont resitry" \
    dst-address=172.20.4.46 dst-port=8080,8443 protocol=tcp src-address=\
    192.168.10.0/24 to-addresses=10.17.254.254
add action=masquerade chain=srcnat comment=\
    "Hair pin store registry cont" dst-address=172.20.4.46 dst-port=\
    8080,8443 protocol=tcp src-address=172.20.4.0/22
add action=src-nat chain=srcnat comment="office2 INTERN NAT DESDE 10.18" \
    dst-address-list=office2INTERN src-address=10.18.0.0/16 to-addresses=\
    172.20.4.99
add action=src-nat chain=srcnat dst-address=148.126.190.0/23 src-address=\
    10.18.0.0/16 to-addresses=148.124.6.152
add action=accept chain=srcnat comment="DON'T NAT internal ranges" \
    dst-address-list=INTERNAL
add action=accept chain=srcnat dst-address=148.124.6.0/24 src-address=\
    10.18.0.0/16
    10.19.0.0/16
add action=accept chain=srcnat dst-address=148.125.6.0/24 src-address=\
    10.19.0.0/16
add action=src-nat chain=srcnat dst-address=0.0.0.0/0 src-address=\
    172.20.150.0/24 to-addresses=148.125.244.253
add action=accept chain=srcnat disabled=yes dst-address=148.124.6.0/24 \
add action=src-nat chain=srcnat disabled=yes dst-address=192.168.10.0/24 \
    out-interface=combo1 to-addresses=192.168.10.230
add action=src-nat chain=srcnat disabled=yes dst-address=172.20.150.0/24 \
add action=src-nat chain=srcnat dst-address=0.0.0.0/0 out-interface=ether1 \
    src-address=192.168.99.0/24 to-addresses=148.124.6.12
add action=src-nat chain=srcnat comment="Sortida per labros" \
    dst-address-list=labrosExternalTargets src-address=10.18.0.0/16 \
    to-addresses=148.124.6.155
add action=src-nat chain=srcnat dst-address=84.89.157.0/24 protocol=tcp \
    src-address=10.18.0.0/16 to-addresses=148.124.6.12
add action=src-nat chain=srcnat dst-address=0.0.0.0/0 dst-address-list=\
    !INTERNAL src-address=10.18.0.0/16 to-addresses=148.125.6.254
add action=src-nat chain=srcnat comment="VPN - NAT Pompem " dst-address=\
    84.89.157.0/24 dst-port=9090 protocol=tcp src-address=10.19.0.29 \
add action=src-nat chain=srcnat comment="Cluster cont cap a office2 intern" \
    dst-address-list=office2INTERN src-address=192.168.10.0/24 to-addresses=\
    172.20.4.99
add action=dst-nat chain=dstnat comment="L2TP softether" dst-address=\
    148.124.6.12 dst-port=500,4500,1701 protocol=udp to-addresses=10.19.0.29
add action=dst-nat chain=dstnat dst-address=73.22.174.253 dst-port=\
add action=dst-nat chain=dstnat disabled=yes dst-address=73.22.174.253 \
    dst-port=22 protocol=tcp to-addresses=10.19.0.29
add action=dst-nat chain=dstnat dst-address=148.124.6.12 dst-port=8080 \
add action=dst-nat chain=dstnat dst-address=148.125.6.253 dst-port=8080 \
    !INTERNAL src-address=10.17.0.0/16 to-addresses=148.124.6.200
add action=src-nat chain=srcnat disabled=yes out-interface=vlan98 \
    src-address=10.19.0.0/16 to-addresses=148.125.6.254
add action=src-nat chain=srcnat comment="VPN - Nat http,https" dst-address=\
    0.0.0.0/0 dst-address-list=!INTERNAL src-address=10.19.0.0/16 \
add action=dst-nat chain=dstnat disabled=yes dst-address=148.125.6.253 \
    dst-port=25 protocol=tcp to-addresses=172.20.4.36
    dst-port=22 protocol=tcp to-addresses=172.20.4.1
add action=dst-nat chain=dstnat comment=HERMES2 dst-address=148.125.244.254 \
    dst-port=993,995,145,587,465,25 protocol=tcp to-addresses=172.20.4.36
add action=dst-nat chain=dstnat comment=HERMES2 dst-address=148.124.6.158 \
add action=dst-nat chain=dstnat comment=HERMES2 dst-address=148.124.6.153 \
add action=dst-nat chain=dstnat comment="store - cont registry" \
    dst-address=10.17.254.254 dst-port=80 protocol=tcp src-address=0.0.0.0/0 \
    to-addresses=172.20.4.46 to-ports=8080
    dst-address=10.17.254.254 dst-port=443 protocol=tcp to-addresses=\
    172.20.4.46 to-ports=8443
    dst-address=10.17.254.254 dst-port=5001 protocol=tcp to-addresses=\
    172.20.4.46 to-ports=5001
add action=dst-nat chain=dstnat comment="Cluster produccio" dst-address=\
    148.124.6.157 dst-port=80,443 protocol=tcp to-addresses=192.168.10.61
add action=dst-nat chain=dstnat comment="Cluster produccio 10080" \
    dst-address=148.124.6.158 dst-port=80 protocol=tcp to-addresses=\
    192.168.10.61 to-ports=10080
add action=dst-nat chain=dstnat comment="Cluster produccio 10443" \
    dst-address=148.124.6.158 dst-port=443 protocol=tcp to-addresses=\
    192.168.10.61 to-ports=10443
add action=dst-nat chain=dstnat comment="Cluster nuc fgrcert" dst-address=\
    148.124.6.151 dst-port=8090,443,80 protocol=tcp src-mac-address=\
    00:00:00:00:00:00 to-addresses=192.168.10.206
add action=dst-nat chain=dstnat comment="Cluster nuc intern" dst-address=\
    192.168.10.31 dst-port=80,443 protocol=tcp to-addresses=192.168.10.206
add action=dst-nat chain=dstnat comment="Cluster nuc intern test" \
    dst-address=192.168.10.32 dst-port=80,443 protocol=tcp to-addresses=\
    192.168.10.61
add action=dst-nat chain=dstnat comment="Clusternuc 153" dst-address=\
    148.124.6.153 dst-port=80,443 protocol=tcp to-addresses=192.168.10.61
add action=dst-nat chain=dstnat comment="Cluster nuc 8" dst-address=\
    148.124.6.8 dst-port=80,443 protocol=tcp to-addresses=192.168.10.61
add action=dst-nat chain=dstnat comment="Cluster comput" dst-address=\
    148.124.6.156 dst-port=80,443,3023,3022,10443 protocol=tcp to-addresses=\
    192.168.10.101
add action=accept chain=srcnat comment=\
    "No NAT per 172.20.40/22 a office2 intern" dst-address-list=office2INTERN \
add action=src-nat chain=srcnat dst-address=0.0.0.0/0 src-address=172.20.4.36 \
    !INTERNAL src-address=172.20.4.0/22 to-addresses=148.124.6.155
    !INTERNAL src-address=192.168.10.0/24 to-addresses=148.124.6.152
    !INTERNAL src-address=172.20.136.0/22 to-addresses=148.124.6.153
    172.16.0.0/16 to-addresses=148.124.6.12
add action=dst-nat chain=dstnat comment="Cloudstation des de fora" \
    dst-address=148.124.6.1 dst-port=6690,5001 protocol=tcp to-addresses=\
    172.20.4.69
add action=dst-nat chain=dstnat dst-address=73.22.174.254 dst-port=80,443 \
    protocol=tcp to-addresses=192.168.10.69
    !INTERNAL routing-mark=IN_73.22.18.130 src-address=10.19.0.0/16 \
    to-addresses=73.22.174.253
add action=dst-nat chain=dstnat dst-address=73.22.174.253 dst-port=3000,8080 \
    protocol=tcp to-addresses=10.17.10.2
add action=src-nat chain=srcnat dst-address=0.0.0.0/0 routing-mark=\
    IN_73.22.18.130 src-address=10.17.0.0/16 to-addresses=73.22.174.253
/ip ipsec peer
add address=0.0.0.0/0 dh-group=modp1024
add distance=1 gateway=73.22.16.5 routing-mark=NET193_145_244
add distance=1 dst-address=172.20.150.0/24 gateway=combo1 routing-mark=\
    NET193_145_244
add distance=1 dst-address=148.125.244.0/24 gateway=ether1 routing-mark=\
    NET193_145_244
add comment=euronet-245 disabled=yes distance=1 gateway=73.22.18.129 \
add distance=1 dst-address=10.17.0.0/16 gateway=vlan2017 routing-mark=\
    IN_73.22.18.130
add distance=1 dst-address=10.18.0.0/16 gateway=vlan2018 routing-mark=\
    IN_73.22.18.130
add distance=1 dst-address=10.19.0.0/16 gateway=vlan2019 routing-mark=\
    IN_73.22.18.130
add distance=1 dst-address=73.22.18.128/30 gateway=eurochat-245 routing-mark=\
    IN_73.22.18.130
add distance=1 dst-address=73.22.22.128/30 gateway=eurochat-545 routing-mark=\
    IN_73.22.18.130
add comment=eurochat-245 disabled=yes distance=1 dst-address=73.22.174.0/24 \
    gateway=vlan2017 routing-mark=IN_73.22.18.130
add comment=eurochat disabled=yes distance=1 dst-address=73.22.174.0/24 gateway=\
add distance=1 dst-address=192.168.10.0/24 gateway=combo1 routing-mark=\
    IN_73.22.18.130
add comment=eurochat-545 disabled=yes distance=1 gateway=73.22.22.129 \
    routing-mark=IN_73.22.22.130
add comment="euronet-1 default gateway" distance=1 gateway=73.22.16.5
add comment="euronet-2 Default gateway" disabled=yes distance=1 gateway=\
    73.22.20.5
add comment="office2 - intern" distance=1 dst-address=10.0.0.0/16 gateway=\
    192.168.20.2
add comment="office2 - intern" distance=1 dst-address=10.1.0.0/16 gateway=\
    192.168.20.2
add comment="office2 -intern" distance=1 dst-address=10.2.0.0/16 gateway=\
    192.168.20.2
add comment="office2 - intern - lab de recerca de Catalunya" distance=1 \
    dst-address=192.168.110.0/24 gateway=192.168.20.2
add distance=1 dst-address=148.126.190.0/23 gateway=148.126.191.253
/ip route rule
add src-address=73.22.174.0/24 table=IN_73.22.18.130
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh address=10.19.0.29/32,10.18.0.0/16,172.20.4.0/22
set www-ssl address=10.19.0.29/32,10.18.10.0/24,172.20.4.0/22 certificate=\
    router disabled=no
set api disabled=yes
set winbox disabled=yes
set api-ssl disabled=yes
/ppp secret
add name=jmca profile=default-encryption service=l2tp
/routing bgp network
add network=73.22.174.0/24 synchronize=no
/routing bgp peer
add name=peer1 remote-address=73.22.18.129 remote-as=13041 ttl=default
add name=peer2 remote-address=73.22.22.129 remote-as=13041 ttl=default
/snmp
set contact=grcert enabled=yes location=grcert
/system clock
set time-zone-name=Europe/Madrid
/system identity
set name=router1
/system ntp client
set enabled=yes primary-ntp=91.226.136.136 secondary-ntp=91.226.136.138
/system ntp server
set enabled=yes
/system routerboard settings
set boot-delay=1s
/tool e-mail
set address=smtp-relay.gmail.com from=mikrotik-router-1@grcert.cat port=465 \
    start-tls=yes
/tool graphing
set store-every=hour
/tool graphing interface
add interface=office2_8
add interface=euronet1
add interface=office2_9
add interface=vlan2019
add interface=vlan2018
add interface=vlan2016
/tool graphing resource
add
/tool sniffer
set filter-interface=combo1 filter-ip-address=148.124.6.1/32 \
    filter-ip-protocol=tcp filter-port=6690
/tool user-manager database
set db-path=user-manager
May I have a wrong srcnat?
