I am trying to send an ip to blackhole using bgp.
My isp only gives me the community ports but nothing more.
I searched and find out how it’s done for ciso/zebra/quagga
My Isp said:
Blackhole community is: 9000:666 (9000 My Isp As number 666 is the blackhole community)
And to do it for Cisco/Zebra/Quagga:
conf t
! Prefix list create. send 192.168.1.11 IP to NULL below
ip prefix-list ISPBLACKHOLE-ACL seq 5 permit 192.168.1.11/32
ip prefix-list ISPBLACKHOLE-ACL seq 10 deny any
! Create Route-map.
route-map ISP-OUT permit 5
match ip address prefix-list ISPBLACKHOLE-ACL
set community 9000:666
exit
route-map ISPBLACKHOLE permit 20
exit
router bgp 1967
neighbor 10.0.0.1 remote-as 9000
neighbor 10.0.0.1 description FIBREETHERNET
address-family ipv4
neighbor 10.0.0.1 activate
neighbor 10.0.0.1 send-community
neighbor 10.0.0.1 route-map ISP-OUT out
end
can someone please translate this to me in Mikrotik Router Os Language
I found another more detailed example in ciso way.
Can someone please translate these ?
attacked ip: 10.0.0.99 /32
first create a static route:
ip route 10.0.0.99 255.255.255.255 10.0.0.2
under bgp entered as /32 and bgp soft clear command run
router bgp 12345
network 10.0.0.99 mask 255.255.255.255 route-map ispipblocks
clear ip bgp 99.99.99.99 soft out
write prefix list then set community in isp-out route map
ip prefix-list attackkedcustomer seq 5 permit 10.0.0.99/32
set community
route-map isp-out permit 15
match ip address prefix-list attackkedcustomer
I am still trying to do this using mikrotik.
I can’t do it
Please some one help
I own my /21 ip block and AS# from RIPE
I setup my BGP using http://wiki.mikrotik.com/wiki/BGP_Case_Studies_1 link:
my current setup is: (Ips and AS changed for security reasons)
[admin@Mikrotik] > /routing bgp instance print
Flags: X - disabled
0 name="default" as=66855 router-id=0.0.0.0 redistribute-connected=no redistribute-static=yes
redistribute-rip=no redistribute-ospf=no redistribute-other-bgp=no out-filter=""
client-to-client-reflection=yes ignore-as-path-len=no
Peers:
[admin@Mikrotik] > /routing bgp peer print
Flags: X - disabled
0 name="MYISP" instance=default remote-address=212.111.222.129 remote-as=9829 tcp-md5-key=""
nexthop-choice=default multihop=no route-reflect=no hold-time=3m ttl=255 in-filter=""
out-filter=to_MYISP address-families=ip
Status:
[admin@Mikrotik] > /routing bgp peer print status
Flags: X - disabled
out-filter=to_MYISP address-families=ip remote-id=212.176.154.65 local-address=212.111.222.130
uptime=21m1s prefix-count=257333 updates-sent=1 updates-received=258801 withdrawn-sent=4
withdrawn-received=186 remote-hold-time=1m30s used-hold-time=1m30s used-keepalive-time=30s
refresh-capability=yes state=established
Routing Filter:
[admin@Mikrotik] > routing filter print
Flags: X - disabled
0 chain=to_MYISP prefix=91.99.16.0/21 invert-match=yes action=discard
I want to announce 91.99.16.5/32 Ip to blackhole community
blackhole community is: 9829:666
I try to add 91.99.16.5/32 to to_MYISP routing filter but what ever I did I can’t do it.
Can please some one point me to right direction.
Hi
At Last without someone helping I tried to do this by myself.
But I don’t know if I’m doing it right or wrong.
Here is what I did:
1- Add 91.99.16.0/21 and 91.99.16.5/32 into Bgp Networks
[admin@Mikrotik] > /routing bgp network print
Flags: X - disabled, A - active
# NETWORK SYNCHRONIZE
0 A 91.99.16.0/21 no
1 A 91.99.16.5/32 no
2- Create a routing filter like this:
[admin@Mikrotik] > /routing filter print
Flags: X - disabled
0 chain=to_MYISP prefix=91.99.16.5 invert-match=no action=passthrough set-bgp-communities=9829:666
And the status:
[admin@Mikrotik] > /routing bgp advertisements print
PREFIX NEXTHOP PEER AS-PATH ORIGIN LOCAL-PREF
0.0.0.0/0 212.111.222.130 MYISP incomplete
91.99.16.0/21 212.111.222.130 MYISP igp
91.99.16.5/32 212.111.222.130 MYISP igp
And now when I test this stuff form outside.
91.99.16.0/21 ips work and respond to ping and traceroute works
91.99.16.5 ip TTL expired in transit. And traceroute stucks and gets into a loop in my ISP router infront of my network not reaching me.
The only thing I am still not sure about is
Line above
Do you think I did everything right or Not?
that looks mostly right. you need to filter out your default route, you shouldnt be advertising that to your upstream.
I did that at first.
Add my ip block to route filters:
Flags: X - disabled
1 chain=to_MYISP prefix=91.99.16.0/21 invert-match=yes action=discard
But If I enable my configuration like that my blackhole community rules are not working.
If I switch places of chains 1 and 0
again blackhole community filter is not working.
I can’t figure out how to create a routing filter which discards my ip blocks but only sends 1 of them to blackhole community.
Can you please tell me how to do that?
remove that last rule and just enter a new blank rule with action=discard. Change the first rule to be action=accept.
Sam
Hi Sam Here’s the final result.
I checked this with my ISP and everything is working like a charm.
Thank you very much.
In this scenario 91.99.16.5 and 91.99.16.33 Ips are under attack and needs to be send to ISP blackhole community - 9888:666
1- Add 91.99.16.0/21, 91.99.16.5/32 and 91.99.16.33 into Bgp Networks
2 A 91.99.16.33/32 no
2- After creating routing filters:
[[admin@Mikrotik] > /routing filter print
Flags: X - disabled
0 chain=to_MYISP prefix=91.99.16.5 invert-match=no action=accept set-bgp-communities=9888:666
1 chain=to_MYISP prefix=91.99.16.33 invert-match=no action=accept set-bgp-communities=9888:666
2 chain=to_MYISP prefix=91.99.16.0/21 invert-match=yes action=discard
3- final status of advertisements:
91.99.16.33/32 212.111.222.130 MYISP igp
Hi static-x
are you located in Italy?
we have our provider (FW) that accept only /24 announcement min. as BGP annuncement
is in your same case?
this was a very old topic.
I am not in Italy but Turkey using Superonline isp.
but this still works as written above.
Thanks.
I have tried, but seems it does not work for me.
The /32 even passed is not accepted
Needs to work with ISP
did you found any way with FW for /32 bgp blackholing ?
