how to send AT commands to the modem Sierra Wireless MC7710?
I have RB411u ROS 5.25 and Sierra mc7710 LTE modem. The modem was connected to the LTE operator, Internet access works.
But modem doesn't accept AT commands.
[admin@TST-MT-ZA-OKNOM] > /port print
Flags: I - inactive
NAME CHANNELS USED-BY BAUD-RATE
0 serial0 1 Serial Console auto
1 usb2 1 auto
[admin@TST-MT-ZA-OKNOM] > /system resource usb print
DEVICE VENDOR NAME SPEED
0 2:1 RB400 EHCI 480 Mbps
1 2:2 Sierra Wireless, Incorporated MC7710 480 Mbps
2 1:1 RB400 OHCI 12 Mbps
[admin@TST-MT-ZA-OKNOM] > system serial-terminal port=usb2 channel=0
[Ctrl-A is the prefix key]
[Q - quit connection] [A - send Ctrl-A prefix] [R - autoconfigure rate]
trying rate 9600
timeout trying rate
Welcome back!
With ROS 5.14 AT commands are sent and the modem answers, but the Internet doesn't work :slight_smile:.
Using newer RouterOS versions it uses LTE interface for that modem and you can’t connect using serial terminal to it. You can use Info command and also send a user-command if you want to send some AT command to the modem.
Also you can switch to oldsyle PPP mode by going into the /port firmware menu and setting the ignore-direct-ip mode to yes and reboot the router.
But user-command option not exist in Info command.
[admin@TST-MT-ZA-OKNOM] > interface lte info 0
<number> -- Item number
append --
as-value --
do --
file --
interval --
once --
without-paging --
[admin@TST-MT-ZA-OKNOM] > interface lte info 0 user-command=AT!INFO
expected end of command (line 1 column 22)
Try to use such command:
/interface lte info 0 user-command=“AT”
[admin@TST-MT-ZA-OKNOM] > /interface lte info 0 user-command=“AT”
expected end of command (line 1 column 23)
make sure that you use the latest RouterOS version - v6.7 and try again.
thanks, command is executed successfully
