Hello ,
I’m trying to send a SMS ,but I get en error - "TimeOut "
using RB411 V6.23 modem MC7700 LTE
/tool sms send usb2 phone-number=+9**56****** message="test" type=class-0
channel=0
failure: timeout
/tool sms print
receive-enabled: no
port: usb2
channel: 0
secret: 0000
allowed-number:
keep-max-sms: 0
sim-pin:
also when I try to “receive Enabled”
I get another error
Couldn’t change SMS Setting - timeout (60)
what could it be?
Thanks ,
hi,
I have the same error with Sierra MC7710 LTE minipcie card:
[admin@MikroTik] > /port print
Flags: I - inactive
# DEVICE NAME CHANNELS USED-BY BAUD-RATE
0 serial0 1 Serial Console auto
1 2:2 usb2 5 9600
2 I usb3 1 9600
[admin@MikroTik] > /tool sms send port=usb2 channel=5 "00367036XXXXX" message="HELLO ALL"
failure: no such channel
uldis
3
if you are using sierra modem as an lte interface it is not possible to send the sms.
but for MC7700 you can set this setting
/port firmware set ignore-directip-modem=yes
it will change form LTE mode to serial with ppp-out interface and then you can send sms
this I know , and it’s working
but why can’t I use “LTE” and send SMS?
also what is the different between using the modem as a LTE and ppp-out interface?
