How to set broadcast limit or broadcast filter
Hello Mikrotik-Forum-User
I build a installation in a german youth center with one RB2011 and four cap ac.
The four cap ac are controlled by capsman on the rb2011.
There are two Networks with sperated SSID connected to the caps.
The first one is a internal WLAN network for the working personal
The second one is a WLAN for Kids use, connected to a VPN gateway on an other internet connection.
The broadcast through the VPN gateway is so much, that all CAPs will stop working. Sometimes more than 3 times a day, sometimes once in a week. Every time we had to restart the CAPs. We have no chance to change some settings on the VPN gateway, because with every updates the settings will be overwritten.
My setting:
On the rb2011:
ether1 is connected to the Internet connection used by internal WLAN and LAN.
ether2-5 are connectet to the CAPs
ether6 is connected to the HP Procurve Switch for internal LAN
ether10 is connected to the VPN Gateway
vlan 10 and ether10 are bridged named “kids”. vlan10 is available at ether 2-5.
ether1-6 are bridged to another bridge named “internal”.
On Caps:
SSID “Personal” is connectet to ether1
SSID “Kids” is connected to vlan 10, available at ether1.
Now the question…
Is there any way to limit or filter the broadcast traffic, witch comes from VPN gateway? I would like to prefer to limit the broadcast traffic at the ether10 incoming. The traffic incoming from ether10 is not routed, only switched.
Thanks for help
David from Germany
Problem still exists…
The CAPac stop working because the system can’t handle the high load of broadcast traffic.
Is there any way to handle this?
Chances in the last days:
Upgrade the RouterOS:
CAP RouterOS Version: 6.42.7
RB2011 RouterOS Version: 6.42.7
I suspect a broadcast storm and depending on type of VPN, I believe it is coming from inside rather that via VPN.
As a starting point, I will move away from bridging / switching everything and rather route out to the 2 internet connections
