How to set dedicated line as the first priority outgoing interface
Hi guys, may I know how to set the dedicated line as the first priority outgoing interface.
Currently , all users traffic is going out the IPsec VPN tunnel even though I already set the dedicated line static route DISTANCE smaller than the PPoe default route DISTANCE. :frowning:
Please help me .Thank you very much.
It is not possible to do this with a plain IPsec VPN.
What you need to do is change the IPsec VPN into a GRE tunnel over IPsec (on both sides), then set a
route over that GRE tunnel at a higher distance than the one you use on the dedicated line.
Hi ,
Do you have the example for setup GRE tunnel over IPsec for mokrotik router?
HI ,
GRE tunnel required the fix public ip right ? but the thing is I don’t have any fix public IP . I only have the ddns IP.
