I’m new to configuring mikrotik devices.
Could any one tell me how i set the ethernet ports to use dynamic IP’s instead of static in the cmd?
(If I’m asking a retarded question please let me know)
Sorry for my grammar.
You need to configure DHCP client: http://wiki.mikrotik.com/wiki/Manual:IP/DHCP_Client
Thank you for your answer.
Just another question.
How do i set the IP? And where do i find the IP that lets me connect to the router via winbox?
Mikrotik devices usually default at 192.168.88.1
But use winbox and connect via MAC. It will keep you from getting disconnected while you build or change the config.
Rkvikstad,
Please read http://wiki.mikrotik.com/wiki/Manual:First_time_startup and http://wiki.mikrotik.com/wiki/Manual:Initial_Configuration. It cover the most basic things about configuring Mikrotik routers.
Thank you for your response, however I do not think my previous post explained my problem properly.
For the moment I can only connect through a serial cable, because the ethernet ports on the router is closed. What I want to know is how i open the ports and set the configurations so that i can logg in via Winbbox.
Thank your for all your help so far. ![]()
