I have an 1100AHx2 which is being used in a small office since it has the nice hardware encryption. However the fan spinning up and down frequently on its own is driving people crazy. Seeing as the temp for the device is way low on its threshold i was going to try and set the fan speed manually and watch the temps. That said I can’t get it to make any changes. I set it to manual mode and see no way to set fan speed via Winbox, then looking at the console I get some adjustments but nothing seems to take effect.
I also can’t find any documentation on the Wiki for this… or I am just blind at the moment. ![]()
Operating temperature range -30C to +60C
[admin@MikroTik] /system health> print
fan-mode: manual
use-fan: main
active-fan: main
voltage: 12.3V
current: 1070mA
fan-speed: 5442RPM
temperature: 27C
cpu-temperature: 37C
power-consumption: 13.1W
Trying to set via console commands:
[admin@MikroTik] /system health> set
cpu-overtemp-check fan-mode heater-control psu2-state
cpu-overtemp-startup-delay fan-on-threshold heater-threshold use-fan
cpu-overtemp-threshold fan-switch psu1-state
when I ‘set use-fan=auxiliary’ it takes the command and switches the fan. However when I try to ‘set fan-on-threshold=50C’ it the fan speed stays the same. I would expect it to turn off until the cpu-temp reached 50C ?
Any help on this would be great, I also don’t see a way to say ‘set fan-speed=2000RPM’ or anything of that manner…
I have also read some have swapped the fans out for other quieter aftermarket ones but I would prefer to try and adjusting these first..
Thanks for the help,
-Brian
