how to set guest wifi if the hAP lite is used only as an access point ?
Hi everyone,
I have a problem with the set up of guest wifi :
  • I have 3 RB941-2nD (hAP lite 2.4G) connected to my Comcast gateway (modem/router combo , IP address 10.0.0.1) and put in different rooms in my house
  • I changed the IP address of hAPs to 10.0.0.2, 10.0.0.3, 10.0.0.4 respectively and turned off the DHCP function of the hAPs and use them only as access point . so all my devices are on the same local network.
But I still struggle with the set up of guest wifi. On the “quick set” , I set the guest WiFi SSID, password ,etc. You can find the SSID but you can never connect it to internet.
Is anyone here knowledgeable to solve it ? Please give me a step-by-step instruction as winbox is pretty new to me.
thank you in advance !
