I have RB433AH and I want to connect GSM Siemens S35i to the board.
I have serial cable, and want to use the GSM like GPRS modem, to login
to the board when the wireless link is down.
any suggestions, ot howtos.
I don’t think that You can do it with RB433AH (or at least it’s not easy), only with RB433UAH and connect it on USB port if your device support it…
Serial on RB is primary for Console output…
Please check:
http://www.mikrotik.com/testdocs/ros/3.0/admin/serial.php
