Dang, I thought I had it attached to my last post…
Router
# 2025-02-06 12:30:36 by RouterOS 7.17.1
# software id = REDACTED
# model = RB4011iGS+
# serial number = REDACTED
add admin-mac=REDACTED auto-mac=no comment=defconf name=bridge \
vlan-filtering=yes
set [ find default-name=ether3 ] comment="b\C3\BCro"
set [ find default-name=ether6 ] comment=knx
/interface wireguard
add listen-port=21841 mtu=1420 name=seedbox1
add listen-port=13231 mtu=1420 name=wireguard1
/interface vlan
add interface=bridge name=guest-vlan50 vlan-id=50
add interface=bridge name=home-vlan40 vlan-id=40
add interface=bridge name=iot-vlan60 vlan-id=60
add interface=bridge name=mgmt-vlan30 vlan-id=30
add interface=sfp-sfpplus1 name=sfp-vlan7 vlan-id=7
/interface bonding
add mode=802.3ad name=nas slaves=ether7,ether8
add mode=802.3ad name=switch slaves=ether9,ether10 transmit-hash-policy=\
layer-2-and-3
/interface pppoe-client
add add-default-route=yes allow=pap,chap,mschap2 disabled=no interface=\
sfp-vlan7 name=telekom use-peer-dns=yes user=REDACTED
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface wifi datapath
add bridge=bridge comment=defconf disabled=no name=capdp
add comment=guest-vlan50 disabled=no name=guest-datapath vlan-id=50
add comment=home-vlan40 disabled=no name=home-datapath vlan-id=40
add comment=iot--vlan60 disabled=no name=iot-datapath vlan-id=60
/interface wifi security
add authentication-types=wpa2-psk,wpa3-psk comment=home-vlan40 \
connect-priority=0 disabled=no name=home-sec
add authentication-types=wpa2-psk,wpa3-psk comment=guest-vlan50 disabled=no \
name=guest-sec
add authentication-types=wpa2-psk,wpa3-psk comment=iot-vlan60 disabled=no \
name=iot-sec
/interface wifi configuration
add channel.reselect-interval=10m..30m comment=home country=Germany datapath=\
home-datapath disabled=no mode=ap name=home security=home-sec \
security.connect-priority=0 .ft=yes .ft-over-ds=yes ssid=\
BuddhasBlessedBunch
add comment=guest datapath=guest-datapath disabled=no mode=ap name=guest \
security=guest-sec ssid=BuddhasBlessedGuests
add comment=iot datapath=iot-datapath disabled=no mode=ap name=iot security=\
iot-sec ssid=BuddhasBlessedDevices
add name=mgmt ranges=192.168.30.100-192.168.30.254
add name=home ranges=192.168.40.100-192.168.40.254
add name=guest ranges=192.168.50.100-192.168.50.254
add name=iot ranges=192.168.60.100-192.168.60.254
add address-pool=mgmt comment=mgmt-vlan30 interface=mgmt-vlan30 name=mgmt
add address-pool=home comment=home-vlan40 interface=home-vlan40 name=home
add address-pool=guest comment=guest-vlan50 interface=guest-vlan50 name=guest
add address-pool=iot comment=iot-vlan60 interface=iot-vlan60 name=iot
/port
set 0 name=serial0
set 1 name=serial1
/system logging action
set 3 bsd-syslog=yes remote=192.168.30.20 syslog-facility=syslog
add bridge=bridge comment=defconf interface=ether1 pvid=40
add bridge=bridge comment=defconf interface=ether2 pvid=30
add bridge=bridge comment=defconf interface=ether3 pvid=30
add bridge=bridge comment=defconf interface=ether4 pvid=30
add bridge=bridge comment=defconf interface=ether5 pvid=40
add bridge=bridge comment=defconf interface=ether6 pvid=30
add bridge=bridge interface=nas pvid=30
add bridge=bridge interface=switch
/interface bridge vlan
add bridge=bridge comment=mgmt tagged=switch,bridge untagged=\
ether3,nas,ether2,ether4,ether6 vlan-ids=30
add bridge=bridge comment=home tagged=bridge,switch,ether2,ether4 untagged=\
ether1,ether5 vlan-ids=40
add bridge=bridge comment=guest tagged=bridge,switch,ether2,ether4 vlan-ids=\
50
add bridge=bridge comment=iot tagged=bridge,switch,ether2,ether4 vlan-ids=60
add interface=sfp-sfpplus1 list=WAN
add comment=wireguard interface=wireguard1 list=LAN
add interface=sfp-vlan7 list=WAN
add interface=telekom list=WAN
add comment=home interface=home-vlan40 list=LAN
add comment=mgmt interface=mgmt-vlan30 list=LAN
/interface ovpn-server server
add mac-address=FE:97:BD:F3:AB:5D name=ovpn-server1
/interface wifi capsman
set ca-certificate=auto enabled=yes interfaces=mgmt-vlan30 package-path="" \
require-peer-certificate=no upgrade-policy=none
/interface wifi provisioning
add action=create-dynamic-enabled comment=5ghz disabled=no \
master-configuration=home slave-configurations=iot,guest supported-bands=\
5ghz-ax
add action=create-dynamic-enabled comment=2ghx disabled=no \
2ghz-ax
/interface wireguard peers
add allowed-address=192.168.70.10/32 client-address=192.168.70.10/32 \
client-dns=192.168.70.1 client-endpoint=REDACTED \
interface=wireguard1 name=pixel preshared-key=\
"REDACTED" private-key=\
"REDACTED" public-key=\
"zA3KVqkFdyeYs8SeH5bBty5q8a6aqZjHmywineHN0EQ="
add allowed-address=0.0.0.0/0 endpoint-address=REDACTED endpoint-port=\
51026 interface=seedbox1 name=seedbox public-key=\
"Tq7MDaNyunVrfko5mLMWoN8rZ08hSJOCpJEPUfQcHVo="
add address=192.168.70.1/24 comment=wireguard interface=wireguard1 network=\
192.168.70.0
add address=10.102.6.2/24 comment=seedbox interface=seedbox1 network=\
10.102.6.0
add address=192.168.50.1/24 comment=guest interface=guest-vlan50 network=\
192.168.50.0
add address=192.168.30.1/24 comment=mgmt interface=mgmt-vlan30 network=\
192.168.30.0
add address=192.168.40.1/24 comment=home interface=home-vlan40 network=\
192.168.40.0
add address=192.168.60.1/24 comment=iot interface=iot-vlan60 network=\
192.168.60.0
add address=192.168.30.0/24 comment=mgmt-vlan30 dns-server=192.168.30.1 \
domain=vlan30.lan gateway=192.168.30.1
add address=192.168.40.0/24 comment=home-vlan40 dns-server=192.168.40.10 \
domain=vlan40.lan gateway=192.168.40.1
add address=192.168.60.0/24 comment=iot-vlan60 dns-server=192.168.40.10 \
domain=vlan60.lan gateway=192.168.60.1
add address=192.169.50.0/24 comment=guest-vlan50 dns-server=192.168.40.10 \
domain=vlan50.lan gateway=192.168.50.1
set allow-remote-requests=yes servers=9.9.9.9,149.112.112.112,8.8.8.8,8.8.4.4 \
verify-doh-cert=yes
/ip dns static
add address=192.168.30.1 name=router.lan type=A
add address=192.168.30.10 name=proxmox.lan type=A
add address=192.168.30.11 name=proxmox2.lan type=A
add address=192.168.30.12 name=proxmox3.lan type=A
add address=192.168.30.20 name=nas.lan type=A
add address=192.168.30.30 name=zigbee2mqtt.lan type=A
add address=192.168.30.40 name=syncthing.lan type=A
add address=192.168.30.50 name=zigbeecoordinator.lan type=A
add address=192.168.40.10 name=homeassistant.lan type=A
add address=192.168.40.20 name=jellyfin.lan type=A
add address=192.168.40.30 name=box.lan type=A
add address=192.168.40.40 name=jellyseerr.lan type=A
add address=192.168.40.50 name=frigate.lan type=A
add address=192.168.40.60 name=flaresolverr.lan type=A
add address=192.168.40.70 name=paperless.lan type=A
add cname=nginx.lan name=jellyfin.REDACTED type=CNAME
add cname=nginx.lan name=jellyseerr.REDACTED type=CNAME
add cname=nginx.lan name=radarr.REDACTED type=CNAME
add cname=nginx.lan name=sonarr.REDACTED type=CNAME
add cname=nginx.lan name=paperless.REDACTED type=CNAME
add cname=nginx.lan name=z2m.REDACTED type=CNAME
add cname=homeassistant.lan name=nginx.lan type=CNAME
add cname=homeassistant.lan name=mqtt.lan type=CNAME
add cname=homeassistant.lan name=radarr.lan type=CNAME
add cname=homeassistant.lan name=sonarr.lan type=CNAME
add cname=homeassistant.lan name=prowlarr.lan type=CNAME
established,related,untracked
add action=accept chain=input comment="dns: accept TCP" dst-port=53 protocol=\
tcp
add action=accept chain=input comment="dns: accept UDP" dst-port=53 protocol=\
udp
invalid
add action=accept chain=input comment="allow Wireguard" dst-port=13231 \
protocol=udp
add action=accept chain=input comment="allow Seedbox (Wireguard )" dst-port=\
21841 protocol=udp
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
add action=drop chain=forward comment="iot: drop all WAN traffic" \
in-interface=iot-vlan60 log-prefix=arenti-outbound out-interface-list=WAN
add action=drop chain=forward comment="guest: drop TCP non-DNS traffic" \
dst-address=!192.168.40.10 dst-port=!53 in-interface=guest-vlan50 \
protocol=tcp
add action=drop chain=forward comment="guest: drop UDP non-DNS traffic" \
protocol=udp
add action=drop chain=forward comment="guest: drop all non-WAN traffic" \
in-interface=guest-vlan50 out-interface-list=!WAN
add action=masquerade chain=srcnat comment=seedbox out-interface=seedbox1
/ip ipsec profile
/ipv6 dhcp-client
add add-default-route=yes interface=telekom pool-name=pool-ipv6 request=\
prefix
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" \
dst-port=33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system identity
set name=Router
/system logging
set 0 topics=info,!wireless
add action=remote topics=info
add action=remote topics=debug
add action=remote topics=warning
add action=remote topics=critical
add action=remote topics=error
/system note
set show-at-login=no
/system ntp client
set enabled=yes
/system ntp client servers
add address=0.de.pool.ntp.org
add address=1.de.pool.ntp.org
add address=2.de.pool.ntp.org
add address=3.de.pool.ntp.org
/system routerboard settings
set auto-upgrade=yes enter-setup-on=delete-key
/system scheduler
add comment=strato interval=1h name=dyndns on-event=\
"/system script run dyndns" policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
start-date=2024-10-20 start-time=17:57:15
/system script
add comment=strato dont-require-permissions=no name=dyndns owner=admin \
policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
source=":global ddnsuser \"REDACTED\"\
\n:global ddnspass \"REDACTED\"\
\n:global theinterface \"telekom\"\
\n:global ddnshost1 \"REDACTED\"\
\n\
\n:global ipddns\
\n:global ipfresh [/ip address get [find where interface=\$theinterface] v\
alue-name=address]\
\n\
\n:if ([ :typeof \$ipfresh ] = nil ) do={\
\n :log info (\"DynDNS: No ip address on \$theinterface.\")\
\n} else={\
\n :for i from=( [:len \$ipfresh] - 1) to=0 do={ \
\n :if ( [:pick \$ipfresh \$i] = \"/\") do={\
\n :set ipfresh [:pick \$ipfresh 0 \$i];\
\n }\
\n }\
\n :if (\$ipddns != \$ipfresh) do={\
\n :log info (\"DynDNS: IP-DynDNS = \$ipddns\")\
\n :log info (\"DynDNS: IP-Fresh = \$ipfresh\")\
\n :log info (\"DynDNS: Update IP needed. Sending UPDATE...!\")\
\n :global str1 \"/nic/update\\\?hostname=\$ddnshost1&myip=\$ipfresh\"\
\n /tool fetch address=dyndns.strato.com src-path=\$str1 user=\$ddnsuse\
r password=\$ddnspass mode=https dst-path=(\"/DynDNS.\$ddnshost1\")\
\n :delay 1\
\n :global str1 [/file find name=\"DynDNS.\$ddnshost1\"];\
\n /file remove \$str1\
\n :global ipddns \$ipfresh\
\n :log info \"DynDNS: IP updated to \$ipfresh!\"\
\n } else={\
\n :log info \"DynDNS: dont need changes\";\
\n }\
\n}"
/tool e-mail
set from="Router <mikrotik@REDACTED>" port=587 server=\
smtp.protonmail.ch tls=yes user=mikrotik@REDACTED
/tool graphing interface
add allow-address=192.168.0.0/16 interface=sfp-sfpplus1
add allow-address=192.168.0.0/16 interface=nas
add allow-address=192.168.0.0/16 interface=switch
/tool graphing queue
/tool graphing resource
/tool mac-server
/tool mac-server mac-winbox
AP Ground Floor
# 2025-02-06 13:30:21 by RouterOS 7.17.1
# model = cAPGi-5HaxD2HaxD
add admin-mac=REDACTED auto-mac=no comment=defconf name=bridgeLocal \
vlan-filtering=yes
/interface vlan
add comment=mgmt interface=bridgeLocal name=mgmt-vlan30 vlan-id=30
add bridge=bridgeLocal comment=defconf disabled=no name=capdp
/interface wifi
# managed by CAPsMAN F4:1E:57:0D:41:A7%mgmt-vlan30, traffic processing on CAP
# mode: AP, SSID: BuddhasBlessedBunch, channel: 5500/ax/Ceee/D
set [ find default-name=wifi1 ] configuration.country=Germany .manager=\
capsman .mode=ap datapath=capdp disabled=no
# mode: AP, SSID: BuddhasBlessedBunch, channel: 2452/ax/Ce
set [ find default-name=wifi2 ] configuration.country=Germany .manager=\
add bridge=bridgeLocal comment=defconf frame-types=admit-only-vlan-tagged \
interface=ether1
add bridge=bridgeLocal comment=defconf interface=ether2
add bridge=bridgeLocal comment=vlan tagged=bridgeLocal,ether1 vlan-ids=\
30,40,50,60
add mac-address=FE:81:CE:1B:D8:03 name=ovpn-server1
/interface wifi cap
set discovery-interfaces=mgmt-vlan30 enabled=yes slaves-datapath=capdp
/ip dhcp-client
add comment=defconf interface=mgmt-vlan30
/ip ipsec profile
/system clock
/system identity
set name="AP Hauswirtschaftsraum"
/system note
AP First Floor
# 2025-02-06 13:31:01 by RouterOS 7.17.1
vlan-filtering=yes
/interface vlan
add interface=bridgeLocal name=mgmt-vlan30 vlan-id=30
/interface wifi
# mode: AP, SSID: BuddhasBlessedBunch, channel: 5720/ax/eeeC/D
set [ find default-name=wifi1 ] configuration.manager=capsman datapath=capdp \
disabled=no
# mode: AP, SSID: BuddhasBlessedBunch, channel: 2467/ax/eC
set [ find default-name=wifi2 ] configuration.manager=capsman datapath=capdp \
disabled=no
interface=ether1
/ipv6 settings
set max-neighbor-entries=15360 min-neighbor-entries=3840 \
soft-max-neighbor-entries=7680
30,40,50,60
/interface wifi cap
/ip dhcp-client
/system clock
/system identity
set name="AP Dachboden"
/system note
