How to set user on hotspot without loging
hello,i have set hotspot on 2.8,but all user like connect need enter username and password.How to set some clients without authentification?
in hotspot make profile with keepalive ie. 30 day (720h), … user will be login once , and never again , … only if user not used net for 30 day (720h) , must login again.
http://forum.mikrotik.com//viewtopic.php?t=3512
Depending on how you have it set up, you can also rework the firewall rules that are set up by the Hotspot to specifically allow addresses, etc and the user never knows they’re actually connected to a hotspot system. It wasn’t hard. Let me know if you would like a hand.
~ Jason
i need can acces:
-for Hotspot users-pay by prepaid,login by www,DHCP,private IP
-for residental user,pay postpaid,static public IP
How to allow MAC or IP addres for residental users so as need not loging via www hotspot,but so as loging automacitally without loging www hotspot
maybe MAC login method is what you need? see hotspot manual on this
see dinamic rule in mangle for hotspot user (when login), and…
make manual same rule for residental user (with IP and MAC of user), and residental user can passthrough without login.
for accouting , do it same way , make manual , all dinamic rule witch you see when hotspot user login. but then you must make some script for accouting manual rule.
but … , easy way … , make profile with keepalive 800000h , and login user only once , but then you have all rule make , no badger to make it. … and user must login again only if not use net for about 100 years , :slight_smile:
