Hello everyone,
is there a way to store two different wifi networks on a rb HAP?
I mean .. I have a wifi network in one plant and a second wifi network in a second plant. I happen to have to move an RB HAP connected to a machine from one location to another.
I would like to allow the use of rb as a wifi client on the two networks without having to reprogram the wlan.
I tried creating a virtual wlan but the second does not connect if the first is not registered.
thanks
Using a connect list with all the networks you want to connect to, might be an easy workaround.
See http://forum.mikrotik.com/t/travel-router/144678/1 (used for a mAP Lite that is used in many locations)
It works perfectly!!
Thanks so much for the help!
[quote=henrymax post_id=839827 time=1610972578 user_id=181873]
I am renting out part of my house, and I want to create a separate WiFi network for the tenants. I don’t want them to have any access to our network. Can I connect two WiFi routers? My internet access is a fiber optics modem provided by the telephone company.
[/quote]
Of course, you can connect two wifi routers with different classes that have the modem as their gateway.
or you can create a virtual AP
Multiple Wifi networks can easily be done in one hAP. Create (add, blue +) a virtual WLAN , with own SSID and security.
To separate the 2 Wifi networks you can either use VLAN’s , or just start a second bridge with it’s own DHCP server. (DHCP server on that extra WLAN might be a problem, not sure, but to be safe add it to the bridge) Add the new virtual WLAN to the new bridge port. In the firewall add a rule to deny access ( “drop forward”) between the 2 LAN subnets. As the new bridge is not part of the LAN interface list, the tenants have no access to the hAP management.
