How to setup a ppp vpn on a RB750G
Hi all
As title suggests I wish to know how I could setup a ppp vpn on a RB750G.
Basically using just TWO interfaces - WAN and a single LAN, for external and internal IPs respectively and be able to connect to the inside network from a remote location through the Internet.
Thanks!
Which one do you want to set up?
PPTP, L2PT or SSTP?
just search in mikrotik wiki for step by step configuration :smiley:
PPTP…
http://wiki.mikrotik.com/wiki/Manual:Interface/PPTP
There you will see some description about PPTP and two step by step example.
