How to Setup hap ac2 are router w/o wifi
Installed a hap ac2 using Winbox/quick Setup, used Home Dual AP. Yet, I want to disable both wlans and use it only as a router.
Tryed disabling both wlans, but when I did the config change to CAP and after a Reboot it started acting as a swich and the IPS router issued the IPs from its Pool (192.168.0.1), rather than (192.168.88.1)
How can I setup the hap ac2 as router,with NO wifi?
Just disable both wlan interfaces and don’t change anything else in Home AP Dual setup.
Just to be specific; disabling the WLAN interfaces is NOT in the Quick setup menu. But under “interfaces” or “wireless”.
Ether1 is your uplink to the ISP. Ether2-ether5 are your LAN interfaces.
And once you do anything outside of QuickSet never attempt to use QuickSet again- that has a great potential of ruining your running configuration.
