WAN IP : 10.0.53.123
NetMask:255.255.255.0
Gateway:10.0.53.254
Interface:FDDI_G_WAN
ROS Version: ros 4.13
2:>setup
i set the ip address on a interface,but i can not choose the gateway setting.
my interface setting:
[admin@MikroTik] /ip address> print
If you are manually setting up the WAN ip in the router, you need to add a default route (IP → Router) in the router so that 0.0.0.0/0 uses 10.0.53.254.
