How to setup metal2shpn as repiter???
can you hellp me to setup metal 2shpn as repetir or ptp bridge
metal to metal
thanks
Set both devices working as ap-bridge, disable wireless bridge, put same channel, same ssid, and activate WDS dynamic-mesh on both, with wlan1 on same bridge.
thanks for you
but that is first time to used Mikrotik
if you can help me for solve this problem with print screen step to step in 2 point but i know you the first point is wisp ap
thanks for you at all
Please Help
Steps in both devices
Step by Step
Beginner in this field.
