How to setup Microtik RB951ui with Centurylink zyxel Q1000z
So my Zyxel Q1000Z router + modem is currently the only device that creates the wifi signal (I’m not a networking guy so not sure how to say this right). Unfortunately, the signal is crap so after doing some research, I bought the Microtik RB951ui router in hope of boosting wifi signal.
The box didn’t provide any instructions so I’m out of clue as to how I need to set this up.
I have an ethernet cable, which I presume is attached to the Microtik and router. But how do I tell my Zyxel router/modem to not broadcast a wifi signal, but instead have the Microtik do it?
Here are the current settings I see in my Zyxel admin console: https://i.imgur.com/5b0hm3g.png
Please advise. Thanks.
Shouldn’t you ask on Zyxel forum how to disable WiFi?
Not sure. I figured this would be a microtik issue.
