Hi Can anyone help me out here, I have a MT AP in APBridge Mode and are running a hotpsot, all works very well. Clients are using built in wireless to connect to the AP and we are using an external radius server.
I want to add a Wireless Client using a MT Router as the CPE and have it connect to the AP and then use PPPoE to Radius. I am not sure how to set up the Client MT CPE or AP to accomdate my situation.
Can anyone assist me. Basically I want to be able to have hotspot users and PPPoE users on the same AP.
I’d recommend that you configure an additional virtual-AP interface on top of your existing physical AP interface and use the new virtual-AP for PPPoE only. This will give you a clean separation with different interfaces for the hotspot and for PPPoE.
The RouterOS manual describes the setup of both, the virtual-AP and of a PPPoE server in sufficient detail.
