What is missing from the following instructions to setup a Mikrotik RB450 as a VPN router?
I placed the cable modem in bridge mode, the Mirkotik RB450 is reachable over the internet via Winbox.exe, I can successfully establish a Windows PPTP VPN, but I am unable to reach any of the target network devices hosted on the LAN I am accessing remotely via the VPN. However, when I go to the Mikrotik Tools and do an IP scan, it is able to “see” the target network devices (assigned static IPs on the LAN) I am not able to reach via the PPTP VPN… HELP! I know just enough to be dangerous, apparently!
Login to the Mikrotik 450 via Winbox.exe, Side menu:
Interfaces
Double-click ether1 to enter ether1 properties
- Rename ether1 “ether1 – Local”
Double-click ether5 to enter ether5 properties - Rename ether5 “ether5 – Internet”
IP > Addresses
Add (+) Local IP address (double-click existing IP to edit if existing)
- Assign to “ether1 – Local”
Add (+) Public IP address - Assign to “ether5 – Internet”
IP > Routes
Double-click “AS 0.0.0.0” to enter properties
- Leave Dst. Address: 0.0.0.0/0
- Edit Gateway: Enter Public Gateway
- Type: unicast
Confirm “Local” Route - Dst. Address: Add local IP range (i.e. xx.xx.xx.x/24)
- Gateway: ether1- Local
- Type: unicast
Pref. Source: Local Gateway (xx.xx.xx.1) - Confirm “Public” Route
- Dst. Address: Add Public Static IP and Subnet (i.e. xx.xx.xxx.xx/28)
- Gateway: ether5- Internet
- Type: unicast
- Pref. Source: Public Gateway (xx.xx.xxx.xx)
IP > Pool
Add Pool (rename dhcp_pool1)
- Addresses (local IP address range: xx.xx.xx.2-xx.xx.xx.12)
IP > Firewall > NAT Tab > Add (+)
General Tab
- Src. Address: (don’t check mark) Local IP Range (xx.xx.xx.0/24)
- Out. Interface: (don’t check mark) ether5 – Internet
Action Tab - Action: masquerade
IP > SNMP Server
SNMP Settings (Enabled: Checkbox selected)
Double-click existing
- Confirm Address: 0.0.0.0/0
- Read Access (checkbox selected)
System > NTP Client
Enabled (checkbox selected)
Mode: unicast
- Primary NTP Server: xx.xxx.xxx.xxx
- Secondary NTP Server: yy.yy.yyy.yy
- OK
Password =
Identity =
PPP
PPTP Server: Enabled (checkbox selected)
ADD (+) PPTP Server (OK)
Profiles Tab
- Double-click default encryption
o Local Address: (local gateway: xx.xx.xx.1)
o Remote Address: (dhcp_pool1)
o Use Compression: yes
o Use VJ Compression: yes
o Use Encryption: yes
o Change TCP MSS: yes
Secrets Tab - Add (+)
o Name: xyz
o Password: 123
o Profile: Default Encryption - Add (+)
o Name: Client
o Password: $@!
