I am trying to setup a local access point using WEP (I now that it is insecure) but I cannot find any WEP option in Wireless Security Profiles. What I have to do?
I am using a RB433AH with Mikrotik 3.20.
Try the following:
Create a new security profile, then select “static key required” and click on “Static Keys” tab. Now
you can select shich WEP you want to use, 40 or 104 when you click on “Key 0” dropdown.
Finishing the new profile just adust your interface to use it.
I think it is all you need but not sure, last time I did it was a long time ago.
Jorge
Thanks my friend, that was not so obvious.
