How to show Interfaces on network map
So I have 10 mikrotik routers on different towers, each has around 15 interfaces connected to Ubiquiti radios (sectors)
Is it possible to show the Interfaces as Devices on the network map?
So, instead of adding each device, I would like to add the 10 mikrotik routers and have an exploded view of each interface, so I can see the speed each sector is pulling.
I created a mockup for clarity.
Just create the interfaces as static objects. Then you can join them with a real link using any interface you like.
