How to show Password
Can I show password, which is saved in DUDE in window which allows to configure the most important settings of the device?
Thank you
If the password is saved in the dude an easy way to do this is to modify the popup notification to include the password. It is “device.password” in the insert variable drop down. Then add that notification to the device in question and trigger an alert by adding a service that the device will not respond with.
